[FXZ] 4.4.2 183.46.10
535 replies to this topic
#1 SamuriHL
  • 39,789 posts
Posted 16 May 2014 - 12:47 PM
POPULAR
WARNING: You REALLY need to UNDERSTAND and read EVERYTHING or you MAY brick your phone!
Purpose of this thread:
To get you, the locked or unlocked RAZR HD xt926 owner, from any version to 4.4.2 (KDA20.62-10.1).
Things you will need:
FXZ
Instructions:
Use the
 with KEEP DATA to flash this on your phone with RSD.
OR
Use the
 with KEEP DATA to flash this to your phone with fastboot.
This will get you a clean OTA install with no data loss.  You will lose root.
Q: My RAZR HD or M is stuck in AP Fastboot mode with a sticky bit failure.  Help?
A:
  Follow that.
See here for locked device root/unlock info:
  • jtelander, hectorlumbago, eman916 and 36 others like this
#2 SamuriHL
  • 39,789 posts
RESERVED
#3 jld
jld
  • 149 posts
  • Current Device(s):Motorola Razr HD MAXX
Posted 16 May 2014 - 01:19 PM
Thanks for the clear, easy to follow post. Question: when will it become possible to flash stock Kitkat on an unlocked HD as you would flash any other ROM? Will that ever be possible?
#4 SamuriHL
  • 39,789 posts
Posted 16 May 2014 - 01:20 PM
Sure.  The FXZ will need to be released and once that happens, this post will get updated to make it even easier.  It'll be possible to flash both locked and unlocked devices with my generated RSD scripts.  Once the FXZ comes out, I suspect roms will follow for unlocked users.
  • jld and superbeast like this
#5 jld
jld
  • 149 posts
Posted 16 May 2014 - 01:39 PM
Awesome. What is the time frame for the FXZ? Just wondering if it's worth going through this now if it'll be months before we see it.
#6 SamuriHL
  • 39,789 posts
Posted 16 May 2014 - 01:43 PM
Unknown. Could be days, could be a couple weeks.
  • jld likes this
#7 iceeyes
iceeyes
  • 10 posts
Posted 16 May 2014 - 01:44 PM
:)  Just followed your instruction and it worked like a charm.
Thank you very much!
  • SamuriHL likes this
#8 kilroy1stcav
kilroy1stcav
  • Twitter:kilroy1stcav
Posted 16 May 2014 - 09:45 PM
I have a rooted only XT926 on 9.18.79, I am stuck can't seem to take the update and can't seem to downgrade, or at least figure it out my own how to. I am using a Mac for a computer system and am new to that, I am a PC dude, but mine died, and I inherited this and its a great machine so I thought I'd try it out, but it's kicking my rear end, and i don't have the money replace the PC, so any pointers would be greatly appreciated!
#9 livinginkaos
  • 15,147 posts
Posted 16 May 2014 - 09:51 PM
OK. NO MORE DOWNGRADING ! PERIOD ! Follow the directions in the op.
Sent from my Unlocked Moto G
#10 livinginkaos
  • 15,147 posts
Posted 16 May 2014 - 09:53 PM
For the Mac you will need to use the HoM in place of RSD since it is java based. Make sure your java is updated.
#11 lordraikalo
lordraikalo
Posted 16 May 2014 - 10:24 PM
Excellent post, thank you. I'll run through this and post back with success/fail.
#12 vakharia
vakharia
  • 58 posts
Posted 16 May 2014 - 10:28 PM
Awesome.
Here is some additional text for the newbies
To get into recover,
hold vol + and - along with power button for a few seconds and then let go all of them.
After getting into recovery you will get a red triangle with android laying down.
Press vol + and -
You will then get a menu. Select the option to apply zip from sd card and then proceed
After following that step, there is some set of messages and the phone reboots.
It goes back to recovery and you see the same red triangle.
Now, hold vol - and just press power button once.
You are now in new version of recovery.
Again from this menu, select option to apply zip file and select the "Blur.... .zip."
It will start the installation again after few seconds of qu 1/1 -- Install /sdcard message
After a while, you will find the phone getting almost stuck at "Patching system files.."
It takes over 5 minutes...
Finally you get a menu after installation completes. You have to choose the reboot option.
After reboot, the "bootloader unlocked" warning disappeared for me. So, I am not sure what happened to the bootloader lock.
  • SamuriHL, superbeast, andrusa and 4 others like this
#13 SamuriHL
  • 39,789 posts
Posted 17 May 2014 - 02:43 AM
They changed the bootloader unlock warning. Nothing to worry about as you're still unlocked if you were before the update.
  • vakharia likes this
#14 taterfry
taterfry
  • 17 posts
Posted 17 May 2014 - 03:35 AM
I'm having to use a friend's mac b/c my pc is usb 3.0 only. can you elaborate on what HoM is?
#15 SamuriHL
  • 39,789 posts
Posted 17 May 2014 - 03:44 AM
[2.0]
House of Moto [2.0]
#16 meat-rack
meat-rack
  • 9 posts
Posted 17 May 2014 - 05:14 AM
i did everything in the orignal post to a T. I get an error when i try to flash the "universal" script in rsd. It starts out good gets to 8/23 which is systm ext4 and flashes it for a little bit and then just goes back to saying fastboot connected, no fail or pass or anything on rsd. On the bootloader it just says flash failure. Any suggestions? im unlocked, stock recovery.
#17 SamuriHL
  • 39,789 posts
Posted 17 May 2014 - 05:18 AM
Check that you're on a USB 2 port, not USB 3, that you're using the original OEM USB cable that came with the phone (yes it matters), and that you have the latest Moto USB drivers (google for it) installed.  Other than that, try a different USB port.
#18 meat-rack
meat-rack
  • 9 posts
Posted 17 May 2014 - 06:50 AM
It was my Motorola USB drivers. I updated them and everything went as smooth as you said. I'm now on official ota KK and rooted. Samurai you truly are the man. Thank you.
  • SamuriHL, cmh714 and superbeast like this
#19 vakharia
vakharia
  • 58 posts
Posted 17 May 2014 - 07:46 AM
Good to know that the bootloader is still unlocked and the warning screen has now disappeared.
I am trying to figure out how to use the CWM image file that has been linked in your post. Do we have to use WinImage and extract some zip out of it?
Edit: Mobile data on CDMA (Reliance) has stopped working. This was working before this update.
Also tested with a GSM SIM card (DoCoMo) and data works fine on that (after APN settings were received from the provider automatically).
In addition now I am seeing some message from Moto-pocalypse to update the Superuser binary (su).
Should I select "Install"?
#20 livinginkaos
  • 15,147 posts
Posted 17 May 2014 - 08:08 AM
Recovery is flashed in fastboot. Fastboot flash recovery nameofrecovery.img Then reboot immediately into recovery. Sent from my S-Offed One M8
