Tapatalk Issue Revisited
29 replies to this topic
#1 Oaklands
Oaklands
  • 312 posts
Posted 27 September 2012 - 10:35 AM
Is there anyway the problem of not being able to go to the first unread message in Tapatalk can be fixed for this site? It would be nice if someone could check into it to see if it is a Tapatalk issue or something specific to this forum. This is the only forum I frequent that where this feature cannot be used. It always takes me to the first post of the thread, then you have to go to the end and backtrack to see where you left off.
I use Tapatalk more than I use my pc.
Thanks.
#2 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 27 September 2012 - 12:02 PM
I use tapatalk a lot on my phone and tablet as well but have never had a issue. When I open a thread, it takes me to the last post just like I chose when I first clicked on one after installing.
#3 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 27 September 2012 - 12:34 PM
You can also revisit that option in settings. The only problem i have with tapatalk is that sometimes it will destroy the format of a post! Such as when trying to update an OP...
#4 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 27 September 2012 - 01:09 PM
I think the OP is referring to the "first unread" post, not the last post. I have the same problem with this forum. If you set it up to jump ti the last post, it will, but if you set it to go to the first unread post, it stays on the first page of the thread. This only happens with droidrzr.com. XDA, Rootz and others do not have this behavior. I have tried multiple things to correct it, but nothing seems to work.
If you guys can verify that it works for you, I'll continue to try, but otherwise I'll just go to the last post and read backwards until I find something familiar. ;)
#5 Oaklands
Oaklands
  • 312 posts
Posted 27 September 2012 - 02:33 PM
G8ordroid is correct. That is what i was referencing.
Rockin' it with my Maxx, iKream and T-Talk
#6 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
Posted 27 September 2012 - 03:15 PM
OK I get what you mean. Honestly I have never used that option before so I've never noticed it. This is the only site I go to so I've got nothing to compare. Ill do a little digging and see what I can find out.
#7 Kirbnite
Kirbnite
  • 37 posts
Posted 27 September 2012 - 03:17 PM
Yeah this site and taptalk, definitely are not friends. The fact that it subscribes to threads on its own and you cannot
Unsubscribe is annoying. Only site taptalk has an issue with, is this site.
#8 Brad92
Brad92
  • 624 posts
  • LocationTexas
Posted 27 September 2012 - 03:27 PM
Same here. I'd also like it if we could "like" posts from the apps. I can on other forums.
#9 Oaklands
Oaklands
  • 312 posts
Posted 27 September 2012 - 04:51 PM
Really appreciate it.
#10 jbag1489
jbag1489
    Themer
  • 167 posts
Posted 02 October 2012 - 02:40 PM
I've been looking into why this happens to, just got tapatalk and love it except for this
#11 C10H15N
C10H15N
  • 12 posts
  • LocationSouthwest
  • Current Device(s):Targa
Posted 11 October 2012 - 04:24 AM
Looks like this issue has been around for awhile. Getting pretty good at "last post back".
"Is this how time normally passes? Really slowly, in the right order?" -Dr. Who
Bionic - Rooted JB 4.1.2 - 5.9.905
#12 k.c.cole
k.c.cole
    Droid Ninja
  • 140 posts
  • Twitter:kcalebcole
  • LocationColorado
  • Current Device(s):Motorola Droid RAZR M
Posted 11 October 2012 - 04:44 AM
Go to the settings in Tapatalk, select Loading behavior, choose Jump to First Unread.
#13 k.c.cole
k.c.cole
    Droid Ninja
  • 140 posts
  • LocationColorado
Posted 11 October 2012 - 04:46 AM
It's not a Tapatalk issue, it's an issue with how the forum software is set up to interact with Tapatalk.
#14 C10H15N
C10H15N
  • 12 posts
  • LocationSouthwest
Posted 11 October 2012 - 05:27 AM
Did that before i started complaining. :P
Sent from my DROID BIONIC using Xparent SkyBlue Tapatalk 2
#15 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 11 October 2012 - 05:28 AM
+1
It's probably something simple, but really hard to find.:lol:
Sent from my RAZR MAXX using Tapatalk 2
#16 Oaklands
Oaklands
  • 312 posts
Posted 11 October 2012 - 05:31 AM
I would think it is something pretty simple since it works on every other forum I use. Many using the same software as here.
#17 C10H15N
C10H15N
  • 12 posts
  • LocationSouthwest
Posted 11 October 2012 - 06:01 AM
Is anyone using the latest tapatalk 2 and not having this issue here?
#18 kunaiboi
kunaiboi
  • 11 posts
  • LocationEast Texas, USA
  • Current Device(s):Motorola Droid Bionic, Kindle Fire
Posted 11 October 2012 - 06:09 AM
I'm having the same issue. (I know that's not what you asked, but I felt like responding anyway.)
#19 Groundhound
Groundhound
  • 132 posts
Posted 11 October 2012 - 06:41 AM
Same issue for me, works everywhere else but not here.
#20 perfoliate
perfoliate
  • 159 posts
Posted 11 October 2012 - 06:50 AM
Its a shame because "first unread" is such a nice option for those of that like to read all posts and stay current with threads. Its much easier on the go than trying to flip back through pages to get to the last post you read manually (which can be done but a nuisance when there exists a more efficient way).
Hope its fixed :-)
