Over 500 Images Altered (so far)
framework-res
SystemUI
Settings
Blur Phone
Blur Dialer
Moto-res
GoogleQuickSearchBox
ICS Analog Clock (separate download)
Droid Razr w/ STOCK 2.3.5 (6.1.744) ROM --- No De-odexing Necessary
*Must be rooted to overwrite system files
*Must have Clockwork Recovery installed
Download BigDX Razr zip file below and place on your external sdcard (sdcard-ext)
Reboot into recovery using bootstrap or adb
Use volume rocker to drop down to "Install zip from sdcard"
Press power button to select
Then use volume rocker to select "Choose zip from sdcard"
Select the zip file you would like to install
After done, Click GoBack and then Reboot
---Theme will install 3 Docks and 6 Wallpapers to /sdcard-ext
--------The Images have a time stamp of 2008 so you will need to scroll all the way to top of gallery to see them
---Signal Bars are Setup for 4 Bars at the moment
--------Will add fifth bar in next release
---Power controls in drop menu will be in Deodexed Verison when available
---Music Widget will be available soon!
---Theme will install BigDX Bionic boot animation.
--------If you do not like goto /data/local and delete bootanimation.zip
---Theme will install beautiful widgets clock skins to /sdcard-ext. This MUST be moved to /sdcard to work
---Icons are NOT included in theme. Those are part of my paid apps in android market
--------Get theme here if you would like ---->>>>
--------I have themes for ADW, LauncherPro & GoLauncher
Want to go back to stock?
