Best Answer livinginkaos , 31 May 2014 - 08:45 PM
Paper clip works just fine
Sent from my S-Offed One M8
Go to the full post
Go to the full post
Posted 31 May 2014 - 07:45 PM
Hello, I have just purchased a Droid Razr HD. How can I put the sim card in the slot along with my micro sd? I don't have the tool and I bought it used, can I use a paper clip or a pin or anything else to move the panel out?
Posted 31 May 2014 - 08:45 PM Best Answer
Sig by
Posted 01 June 2014 - 03:14 AM
Thank you very much!
