I take no credit what so ever for this.... Just wanted to share with the community, Its Kexec runs really smooth
no deep sleep but battery life is good... he took his time on this and did a really great job...
This disturbingly dark nugget of android goodness is my vision of sickness built from a base being developed by the STS Dev Team..It's AOKP in it's darkest form developed on the KEXEC bypass .... I proudly introduce to you....
Demented Bean...this is The Awakening
All thanks and credit goes to:
Dhacker29
Hashcode
Team Kang
Disclaimer
Neither myself nor any of the Droidrzr staff are in anyways responsible for anything that could possibly happen to your phone by installing Demented Bean...Even if it burst into flames, turns into a pile of gelatenous goo, or starts howling like a wookie...As always, make a nandroid backup BEFORE flashing...
Features
Built on the Kexec Bootloader Bypass, BeatsControl, build.prop tweaks, init.d support, full inversion package, butt load of color tweaks, modded lockscreen, Zenyth soft keys, performance options, custom font, and a buncha other $#!7
Known Issues
Still buggy....Work in progress....
Installation
You MUST install using Razr Safestrap 2.11...Download rom and gapps and put on either sd card, boot into recovery and wipe data, cache, dalvik cache, and mount / format system...flash rom and THEN flash gapps (do not use any other gapps with this rom other than what i posted in this op) and reboot...After Initial setup is complete REBOOT....
Download
Donate
By no means is it a requirement but it is always appreciated...If you like what i've done then the beer fund is always there
This donate link has nothing to do with myself, strictly to the developer
Changelog
B2: 10/02/12
completely restyled UI (Made this woof Sexy)
init.d tweaks
working data ?
camera works with some market camera apps
DEMENTED Wallpaper
