Install Custom ROM and Safestrap
Posted 17 June 2014 - 09:49 AM
Posted 17 June 2014 - 10:30 AM
Ok I installed a Safestrap now I cant get onto my phone
Posted 17 June 2014 - 10:39 AM
Why are you safestrapping?
Get the latest KitKat OTA, if you're not on it, and unlock your bootloader! Forgo safestrap as their are a limited # of ROMs for the XT926.
Of course, there aren't any new ROMs ready-for-prime-time under KK right now, but having that unlocked bootloader is precious. We must haves it, my precious!
Posted 17 June 2014 - 10:40 AM
I am unlocked and was rooted but now I cant even boot up my phone
Posted 17 June 2014 - 10:57 AM
now im stuck at the droid eye for ever
Posted 17 June 2014 - 11:10 AM
Not sure what safestrap will do for you. Just go into recovery and try a wiping of the cache and dalvik. If that doesn't work, then it's time for a factory data reset in recovery. Finally, if that doesn't work, I would reflash a complete KK image to your phone and see if that works (use the full which wipes data across the entire phone except for your external SD card).
Posted 17 June 2014 - 11:14 AM
alright im back up and running just reflashed a kitkat back on
Posted 17 June 2014 - 03:47 PM
Read, read, read, prior to doing anything else to this phone. Knowledge is power...
- ibolski likes this
Posted 17 June 2014 - 03:57 PM
- RikRong likes this
Posted 18 June 2014 - 04:43 AM
Posted 18 June 2014 - 05:04 AM
Anyone know how I can install a custom ROM ?
You'll need to unlock the BL and install a custom recovery. With that being said, none of the custom ROMs out there right now will work on the new bootloader/kernel. DHacker has a test build of CM11 out right now that works, somewhat.
Posted 18 June 2014 - 05:05 AM
Posted 18 June 2014 - 05:15 AM
Most users prefer TWRP. The TWRPs for the Razrs are unofficial, so you won't be able to get them of the TWiRP site. I can't link Android Hosting here at work, but you can get the recovery from the link in the OP of this thread:
.R. Long: Pixel 5
Posted 18 June 2014 - 05:59 AM
As of now, no roms for those who are running KK have been completed. Dhacker has one in progress that you can find here. Make sure you get TWRP installed and make a backup before you try to install custom roms for ease of recovery if it doesn't work out.
Posted 18 June 2014 - 06:19 AM
Posted 18 June 2014 - 02:20 PM
With all do respect man, you need to do some research yourself, that's the only way to learn. There are tons of how-tos out there for Android.Anyone link me to a video on how to install custom recovery something not good with text instructions
Sent from my HTC6525LVW using Tapatalk
Posted 18 June 2014 - 02:23 PM
Posted 18 June 2014 - 05:13 PM
