Where Are The Wireless Antennas?
Posted 10 October 2012 - 02:21 PM
As I was "refurbishing" my Droid Bionic with all new plastic housing and a new digitizer, I had some difficulty moving a few components that were attached to the back housing over to the new one... These components were glued to the back housing by some kind of adhesive, and while I was trying to remove them, they tore apart. They are basically black, rubberish strips that have two metal leads at the end of them, which connect to the motherboard. Throughout the strips, they appear to consist of two circuit traces, and they seem like rather simple components. There's three of these, and I was only able to remove one successfully without tearing it. All three attach to the rear housing of the Droid Bionic, but they're very easily overlookable because they blend right in with the black casing.
I'm about 90% sure these are antennas, but I just wanted to clarify with someone here that they are. Since I put the phone back together, my signal has been terrible. At first, I thought they were the three microphones, but then I tested the microphones and they seem to work fine. So if anyone knows what I'm talking about, or what parts I'm referring to, and if they know whether these pieces are antennas or not, that'd be great. Thanks. ^^
Posted 10 October 2012 - 06:34 PM
Posted 10 October 2012 - 07:29 PM
I watched a video and was actually able to confirm that the strips are indeed the antennas. The bottom one is for LTE/CDMA, and the side one is for WiFi (both of which I'm missing, which would make sense for why I'm getting horrid signal xDD).
It probably sounds like I was being reckless, but I really wasn't. The problem is that the new rear bezel I ordered didn't come with ANY of the components that are supposed to be attached to it, so I had to manually remove them from my OLD bezel to the new one. Peeling the antennas away from the bezel without ripping them apart is an extremely difficult feat. I was also thinking, since the antenna is such a simple component of the phone, I could perhaps try constructing my own, by stripping wires so that they're bare, and then taping them down in the areas where the antenna paths are. Not sure how effective that would work though..
Posted 10 October 2012 - 07:30 PM
I don`t personally own a Bionic, but maybe this will give you some insight on what those are.Hi.
Posted 10 October 2012 - 07:35 PM
Posted 10 October 2012 - 08:27 PM
I'm just hoping that this other part I ordered has those antennas included with the rear bezel, or I may find myself having to construct my own. They're such an obscure component of the phone. I looked on ebay for replacement antennas, but found nothing.
Posted 12 October 2012 - 05:04 AM
"We are the People Verizon warned you about"
8 GB Bionic JB, 16 GB Bionic JB, Bionic Lapdock X2, Razr Maxx XT912 JB, Razr M XT907 JBLX
Posted 12 October 2012 - 05:13 AM
But seriously, good luck on your repair quest.
Posted 14 October 2012 - 02:15 AM
Posted 14 October 2012 - 07:20 PM
Posted 03 November 2012 - 10:26 PM
has anyone tried those "goodie" protectors????
Regards.
