Then it's down to port/driver/cable issue. You can try switching to the House of Moto and use the fastboot mode but I doubt it'll change anything. You can try, though.
#21
Posted 09 July 2014 - 04:33 PM
#22
Posted 09 July 2014 - 04:40 PM
i guess if that doesnt work ill have a nice paper weight to look at . thank you for all your time and information
#23
Posted 09 July 2014 - 04:45 PM
It's not bricked. Well, not permanently. The issue is that it failed to send the system partition. So as a result of that you're in the state you're in now. System is over a gig in size which is why I say it's incredibly likely to be a cable/port/driver issue. Must be a USB 2 port. Using the original OEM cable that came with the phone (yes, it matters), and you must have the latest moto USB driver installed.
#24
Posted 09 July 2014 - 04:54 PM
#25
Posted 09 July 2014 - 04:58 PM
going to try every possible combination of cords/ports available
#26
Posted 11 July 2014 - 04:18 AM
#27
Posted 13 July 2014 - 12:38 PM
If you don't want to look at it, I'll take it
But in all seriousness, make sure your drivers are up to date, make sure its a Motorola cable, make sure you have all correct settings, and make sure you have the right fxz.
Sent from my DROID RAZR M using Tapatalk
