Randomly Can't Get Audio Out Of The Phone Speaker
Posted 01 November 2012 - 04:43 PM
In the past a reboot fixed this, but not today. It happened on eclipse 1.1, after no success with rebooting and what not i booted back into cm10 and the lack of speaker sound continued. I even jumped back to my stock rom, same deal.
Ive tried opening different apps, wipping data/cache/dalvik and fixing permissions. Nothing seems to work..
Anyone have any ideas? This is driving me crazy.
Posted 01 November 2012 - 05:03 PM
Posted 01 November 2012 - 05:19 PM
Posted 01 November 2012 - 05:51 PM
Posted 01 November 2012 - 06:24 PM
Posted 01 November 2012 - 07:11 PM
Posted 02 November 2012 - 09:47 AM
Posted 02 November 2012 - 12:19 PM
Posted 02 November 2012 - 12:54 PM
Posted 05 November 2012 - 04:22 AM
Posted 08 November 2012 - 01:43 PM
Kinda on topic, Not really sure if its related to ICS, but I've lost all volume in my ear speaker. I cannot even hear a call (volume is there...just very very quiet) unless I put them on speaker? I'm thinking its a hardware issue, but before I plunk down the $ for a new speaker just thought I'd ask if anybody else experienced. Any/All suggestions appreciated.
One time I put a screen protector on my phone that covered the ear speaker, easy mistake and makes the ear speaker supper low. Did you maybe get a new screen protector recently? If not i cant image its anything but hardware
Posted 08 November 2012 - 07:13 PM
It's a temp fix for me and I'm having to switch over to speakerphone more often than not.
Posted 12 November 2012 - 11:12 AM
...OMG.........OK...so no new screen saver, however, I do think my speaker is not positioned correctly.....I'm thinking of pulling it apart to try to re position it....looks like it fell out of its casing hole and it really doesn't look centered anymore. Can anybody post a close up pic of their ear speaker so I can verify my theory?
Posted 12 November 2012 - 12:20 PM
Waiting for the day a reboot doesn't fix it....
And to be more specific, I am talking about the speaker on the back of the phone.
Posted 12 November 2012 - 02:04 PM
It is a pretty common issue, I have read about issues with the phone speaker from a lot of different people over the years. I have had the audio just stop for no reason about 10 times or so but a reboot fixes it for me.
With that one I basically have to tap the bottom a few times.. All these seem to get jostled loose since they basically sit on connections instead of being soldered
Sent from my Icarus HD Edition Bionic
Posted 30 November 2012 - 04:32 PM
Issue 1: no sound - I change the ringtone. The audio returns.
Issue 2: no media (including video) - I go into system tuner pro and under the task manager and select the Kernel files. I then kill the "system...mediaserver" file. This will restart and the media returns.
Issue 3: bt left on - I use a moto roadster. If I shut off the roadster before I toggle the bt off I lose my sound. I have to turn the roadster back on then toggle the bt off.
I have had a few times where the whole system will bog down to a standstill. Then the system will restart without rebooting. I despise reboots. I get stuck in a boot loop. Which is a whole other issue that is not specific to this ROM.
It started with 232 ICS ROM's.
I hope the troubleshooting helps.
