Question For My Razr Hd Folks. Doss The Hd Have A Gyroscope And If It Does, Is It Enabled?
Posted 02 November 2012 - 12:25 AM
Thank you for the answers.
Posted 02 November 2012 - 01:31 AM
Posted 04 November 2012 - 08:04 PM
Posted 04 November 2012 - 10:01 PM
I was able to install the new camera and photosphere does work.
Weird i thought i find out later that the hd does not have a gyroscope.
Posted 04 November 2012 - 10:24 PM
Posted 07 November 2012 - 04:47 AM
Posted 07 November 2012 - 05:48 AM
Posted 22 December 2012 - 07:20 PM
I installed the 4.2 camera and the app always crashes when I try to select photosphere. Panorama and regular stills works fine but I can't get photosphere to work.I was able to install the new camera and photosphere does work.
Posted 22 December 2012 - 10:03 PM
Did you copy the appropriate libs into your system/libs folder?
Also, I found a thread that says you need to make a couple build.prop edits to make it work, but I don't think that's the case.
Posted 22 December 2012 - 10:19 PM
Posted 23 December 2012 - 06:35 AM
Originally I only found and installed the gallerygoogle.apk file which had been posted as an individual download over on XDA. After some more searching around last night I found the full zip file with the lib files and added all the relavent files. Now everything seems to be working including photosphere and editing in the gallery.
thanks all for the help.
Posted 23 December 2012 - 08:05 AM
