"Knock On Wood" Theme
(Current Version 1.0.3)
Hi all, here is a theme based on nature with an emphasize on wood. I had an idea that when the people are gone, everything will revert back to nature. That was the basis for this theme. Helping nature out by making a wooden Razr
Custom boot animation:
I am not responsible for anything that may happen to your device. (…Nothing should happen)
Thanks: – Creator of Flick Rom. - bootanimation help. - custom icon help. If I have missed anyone, please let me know!
THIS IS BASED ON Flick 5.0 ROM:
What apk's have been themed (some more than others):
- Framework-res
- Browser
- Camera (Razri_Cam)
- Contacts
- Gmail
- MMS
- Phone
- SystemUI
- Bootanimation – Taken from "Planet Earth - Seasonal Forest" documentary with new sound.
- Battery Icon changed (with 1% battery changes).
- Status Bar Icons.
- Dialer font.
- Lockscreen Clock and system font.
- Dock and Lockscreen Icons.
- Default Wallpaper – Can be changed to any wallpaper.
- White text in SMS.
- MANY different icons.
- Removal of ICS Blue from status bar pull down.
- Suggestions?
Installation:
(This is assuming you are already on Flick 5.0)
- Knock_On_Wood_v1.0.3 DOWNLOAD:
- Download and install onto SD Card.
- Reboot into Recovery Mode SafeStrap (I have only tested using SafeStrap v3.05).
- If you want to be safe: Wipe Cache, Wipe Dalvik Cache (In “Wipe”).
- Choose “Install”
- Locate “Knock_On_Wood_v1.0.3.zip”
- "Swipe to Confirm Flash"
- After installation, Reboot, and enjoy!
Icon Pack:
This is a zip of various icons like the dock icons. Download, unzip and move the icons you want to your SD card. To change you will need to change each icon individually. Long press on the icon, select "Edit", press icon, and locate the icon you want to replace it with. Then press "OK."
Change Log:
v1.0.2
Modified to work with Flick 4.0.
v1.0.3
Modified to work with Flick 5.0.
Removed a little more ICS blue.
Small change to the start of the boot animation.
Changed notification pull down background.
If anyone would like to pull and edit to use things for theming etc, go ahead. If you do post, all I ask is to be added under credits with a link to the page. You do not need to ask.
