When Will There Be Deals On Outright Phone Purchases?
Posted 04 November 2012 - 05:41 PM
I don't need a dev edition, just a maxx. I want new but will sit tight if they drop to the $400 to $500 range as new...if that is possible.
Posted 04 November 2012 - 05:44 PM
Posted 04 November 2012 - 07:09 PM
Get a new line. Activate a dumb phone in the new line and put the Maxx HD on your line...lol
Sent from my RAZR MAXX HD using Tapatalk 2
Posted 04 November 2012 - 07:35 PM
If you want a Maxx HD and you don't want to spend $6-700 you could always do like I did:
Did you lose the unlimited plan. Or you were able to add a dumb phone for 10 a month
That's exactly what I did. Although I already had the dumb phone line.
Posted 04 November 2012 - 07:45 PM
Nope, I added the line with it's 2GB plan, and then I had to go find a dumb phone to add on, dropping that line to $9.99 a month, and then I switched the Maxx HD to my main line and that's it. Lol
I already had 2 dumb phone lines, but they don't have upgrades available yet, so I had to add a 3rd...lmao! I have 5 lines for just my wife & I. She uses a RAZR Maxx, I use a RAZR Maxx HD, and the other 3 lines are spared I have because I used them to get phones at upgrade cost...
Posted 04 November 2012 - 08:01 PM
Posted 04 November 2012 - 08:11 PM
Can you transfer your upgrade line with unlimited to your dumb phone line and upgrade that line to 2 gig plan then put the dumb phone back on the line and put the new phone on your main line which has unlimited.
Huh? You can upgrade a line and transfer the device to another line, but you cannot transfer the upgrade from one line to another, to my understanding. For example, I have an upgrade available on my main line in November...which will not be used, because I do not want to lose unlimited data. But, when I upgrade one if my spare lines, I can do that, and activate the new device to my main line, this keeping the new line on the $9.99 price. OR, I can get a new line and put that phone in my current lime, and activate a dumb phone to the new line, this making that a $9.99 per month line....
Posted 04 November 2012 - 08:16 PM
I thought you can transfer upgrades to other lines on your account. I did it last year but not sure if you can still do it this year. My main line with unlimited is due for an upgrade in December. If I can transfer that upgrade to my dumb phone line, then I might get to keep unlimited plan
Posted 04 November 2012 - 08:17 PM
Hmm...I was not aware you could do that...I will have to check into that, lol
Posted 04 November 2012 - 08:19 PM
I was offered by Verizon rep to take my wife's upgrade
Posted 04 November 2012 - 08:21 PM
Yes, but that likely meant you upgraded her line & put the device on yours...at least that's how I'd understand it. I would definitely ask them that specifically before doing it, to make sure you don't end up with a nasty surprise lol
Posted 04 November 2012 - 08:26 PM
Posted 04 November 2012 - 08:29 PM
I can confirm that you can transfer upgrades between lines on a plan. If you were to upgrade through the Verizon site it would ask you if you want to transfer an upgrade from another line.
Woooooo hoooooo. So I can keep my unlimited since I already have a dumb phone line. Apparently that dumb phone is smarter than my other phones since its helping me keep my unlimited plan.
Posted 04 November 2012 - 08:33 PM
Ummmm... yeah not sure about that. I thought when using ANY upgrade on a plan you were automatically moved to a family plan and lost any unlimited. Am I wrong here??
Posted 04 November 2012 - 08:38 PM
That's what I'm confused. Do you have to add a new line and get the 2gig data plan then put a dummy phone on that line and transfer the new phone to unlimited line
Posted 04 November 2012 - 08:39 PM
I believe you are wrong. I was going to upgrade my spare line to get the Maxx HD and keep my unlimited, but the only reason I did not is because it doesn't upgrade until march
Posted 04 November 2012 - 08:42 PM
Hmmm... Is that because it was a line that had no data plan (dumb phone)?? Maybe it's when you upgrade a phone with a data plan that you lose unlimited. I gotta figure this out. I have 2 lines I will be upgrading in the next few weeks and would love to keep unlimited if possible
Posted 04 November 2012 - 08:44 PM
Then keep is posted if you keep unlimited
Posted 04 November 2012 - 08:48 PM
