Highest Stable Overclock/ Voltage?
Posted 23 January 2012 - 01:51 PM
Posted 23 January 2012 - 03:52 PM
:-D :-D
Posted 23 January 2012 - 04:00 PM
Posted 23 January 2012 - 04:42 PM
Posted 23 January 2012 - 04:45 PM
That's what I used. Fairly easy to do.
Sent from my DROID RAZR using Tapatalk.
And.. thanks to tekahuna for his work on this..
Posted 23 January 2012 - 04:53 PM
Posted 23 January 2012 - 06:11 PM
So are you using SetCPU to bump it up and down or another app?
Posted 23 January 2012 - 07:18 PM
I'm using rom toolbox pro. Lots of goodies packed in there.
Posted 23 January 2012 - 07:41 PM
Posted 23 January 2012 - 09:03 PM
I pulled mine down to 900 max, noticed no performance issues at all and a fairly noticeable battery life increase.
I tried bumping mine down to 900 but set CPU still recognizes 1000 as being the the Max. Although 900 is the what it's set to, still runs at 1000. Any ideas. I attempted to change voltage to 1250000 as well if that means anything. Don't even know if that is functional yet
Posted 23 January 2012 - 09:19 PM
<br /><br />That link takes you to the instructions. I think it was 1250000000 1388000. I'll look. I just rebooted and don't have access above1200 again<br /><br />Can someone please post there script?
Posted 23 January 2012 - 09:26 PM
Posted 23 January 2012 - 10:40 PM
If you look in instructions for 0.1 betas its only cpu u can set not voltage right?
Yes for 0.1. But they have a .2 which does voltage.
Posted 23 January 2012 - 10:49 PM
<br /><br /> <br /><br /> after "1250",Did you put 3 zeros (1250000) or six (1250000000). It should be six after "1250". I think putting less will underclock it a lot.<br /><br />Also, follow the instructions. Use the line for checking it in the terminal. <br /><br /><br />I'll post what it should look like in a minute<br /><br />I tried bumping mine down to 900 but set CPU still recognizes 1000 as being the the Max. Although 900 is the what it's set to, still runs at 1000. Any ideas. I attempted to change voltage to 1250000 as well if that means anything. Don't even know if that is functional yet<br /><br />Sent from my DROID RAZR using Tapatalk
EDIT: added screens & corrected zeros
Posted 23 January 2012 - 11:13 PM
Edit: I just checked and cannot read the text on the terminal screen. Sorry, don't know how to remove
Posted 24 January 2012 - 03:37 AM
Posted 24 January 2012 - 09:01 AM
:-D :-D
Posted 24 January 2012 - 10:04 AM
+1 to ROM Toolbox Pro, worth it's weight in gold. It's like 10 different root/performance/theme tools wrapped into one.
Yep. And I could get the max to 900 but it still went to 800 or 1000. I'm just upped it to 1300 Mhz @ 13.8. So far so good
Posted 24 January 2012 - 10:36 AM
Posted 24 January 2012 - 12:17 PM
Edit:Maybe I don't have the right one or something... I noticed above that someone said there should be six zeros after the 1250, but the instructions have me typing in 1122000000 after echo. Also, by "unpacking modules and place them in system/lib/modules", are they talking about just the .ko files or all files in the zip?
