Highest Stable Overclock/ Voltage?
#41
Posted 05 February 2012 - 05:20 PM
#42 Guest_coryjohn87_*
Posted 05 February 2012 - 06:00 PM
#43 Guest_coryjohn87_*
Posted 05 February 2012 - 06:05 PM
i have been running 1375 all day fineThose are impressive results. Have you run it long enough at those speeds to see what it does to battery life?
#44
Posted 05 February 2012 - 06:08 PM
"i have been running 1375 all day fine"
Were you pushing it or just using normal?
#45 Guest_coryjohn87_*
Posted 06 February 2012 - 01:30 AM
i was pushing very hardIts not good. I try to keep it plugged in. but I had the gov on performance so that doesn't help.I'll let you know when i'm not pushing it hard. I was running all kinds of stuff
#46 Guest_coryjohn87_*
#47 Guest_coryjohn87_*
Posted 06 February 2012 - 01:32 AM
#48
Posted 06 February 2012 - 06:39 AM
Edit: I have also noticed that my phone is faster and smoother set on mot hotplug.
#49
Posted 06 February 2012 - 04:57 PM
Not a good bench. But I'm not crashing. If only voltage wasnt capped. But then id be melting stuff. 1800mhz performance governor. Cfq
#50 Guest_coryjohn87_*
Posted 06 February 2012 - 05:03 PM
113.08KB 58 downloadstry taking it of performance an put it on the first one mot_hotplug i found i got bad results on performance
#51 Guest_coryjohn87_*
Posted 06 February 2012 - 05:08 PM
yea same here about being on mot hotplugIt's funny how these phones all act differently. I have achieved best results at 13.50 MHz and voltage at 13.80. Running DT's Abysm rom, I get a minimum 24hrs. battery life. I am waiting on my battery to charge back up so I can re-flash Abysm and reset my overclock values. I have been using the latest alpha build of ICS and it runs through benchmark apps faster than I have with the phone overclocked. My quadrant was over 3000. I will post a screen when I am back up and running. I haven't been able to get higher than 96 mflops on Linpack though.
#52
Posted 10 February 2012 - 12:00 AM
I just want to make sure i saw 1800Mhz over there and i was wondering how your device act with that mich power and the battery life?
Whenn i overcloked my old Droid 2 Global if i did it too high the fone would slow down like hell LMAO. like i said just want to hear your comments on OC ing. Thanks. Sal.
#53
Posted 10 February 2012 - 07:48 PM
Anyone care to explain getting this to run at boot? ive tried reading the rootzwiki threads and such. its a jumbled mess it looks like and is making me head hurt.
#54 Guest_coryjohn87_*
Posted 10 February 2012 - 08:21 PM
i have gotten mine to work on boot pm me an i will help you with iti got 1325 mhz stable. 1350 would hotboot when switching between browser and text messaging. to be honest could have lived with it but 50 mhz is NOT worth it lmao. also noticed better battery life? not sure how that happened. second day on a new flash tho maybe rom still settling. unusually good nonetheless from my experience.
#55
Posted 10 February 2012 - 09:36 PM
I also need some help with an init.d script/values and what version to install...if you can help me too.i have gotten mine to work on boot pm me an i will help you with it
#56
Posted 11 February 2012 - 01:22 PM
#57
Posted 12 February 2012 - 10:30 AM
#58
Posted 15 February 2012 - 08:22 PM
i got 1.35GHz stable at the 13V. if i go up to 1.4GHz it slows way down and is really really laggy.
Is there any noticeable improvement?
#59
Posted 29 August 2012 - 08:41 PM
#60
Posted 30 August 2012 - 07:18 AM
