"Pink Floyd" Theme
(Current Version 1.0.1)
Hi all, this is a port over to (Aokp) Licorice 1.0 *non Kexec* rom as requested by a few people.
Custom boot animation:
I am not responsible for anything that may happen to your device. (…Nothing should happen)
Thanks: – Creator of (AOKP) Licorice 1.0 Rom. - bootanimation help. - custom icon help.
THIS IS BASED ON (Aokp) Licorice 1.0 *non Kexec* ROM:
What apk's have been themed (some more than others):
- Framework-res
- Browser
- Contacts
- Gmail
- MMS
- Settings
- Phone
- SystemUI
- Bootanimation – Taken from "The Wall" movie.
- Battery Icon changed. (with 1% battery changes).
- Status Bar Icons.
- Dialer font.
- Lockscreen Clock Font - Font inspired by "The Wall."
- Dock and Lockscreen Icons.
- Default Wallpaper – Can be changed to any wallpaper.
- Settings icons.
- MANY different icons.
- Since this is only a port, few changes may be ported over when made to the main Pink Floyd theme.
- Suggestions?
Installation:
(This is assuming you are already on (Aokp) Licorice 1.0 *non Kexec* )
- Pink_Floyd - (AOKP)Licorice_1.0 DOWNLOAD:
- Download and install onto SD Card.
- Reboot into Recovery Mode SafeStrap (I have only tested using SafeStrap v3.05).
- If you want to be safe: Wipe Cache, Wipe Dalvik Cache (In “Wipe”).
- Choose “Install”
- Locate “Pink_Floyd - (AOKP)Licorice_1.0.zip”
- "Swipe to Confirm Flash"
- After installation, Reboot, and enjoy!
Default_wallpaper (Just in case):
Change Log:
(To come)
If anyone would like to pull and edit to use things for theming etc, go ahead. If you do post, all I ask is to be added under credits with a link to the page. You do not need to ask.
