Battery replacement
19 replies to this topic
#1 smb5769
smb5769
  • 30 posts
  • LocationUnited States
  • Current Device(s):Droid RAZR HD, Droid Turbo
Posted 01 September 2014 - 09:36 PM
Does anyone know where you can get a good new battery for a RAZR HD? Moto won't go. They said no. I think my battery is bad and it makes me sad... :D:
#2 johnthehillbilly
Posted 02 September 2014 - 02:08 AM
You could start on eBay ..... (That's where I would start)
HD tapadriving..... hillbilly style!!!
#3 smb5769
smb5769
  • 30 posts
Posted 02 September 2014 - 04:13 AM
I'm kinda scared of eBay. I got burned bad once buying something from an individual. I'm worried with my luck I'll spend new money on a used battery. Is batterymonster.com good? They have them for 20 bucks.
#4 johnthehillbilly
Posted 02 September 2014 - 04:25 AM
I'm not sure about batterymonster.com .... Just make sure about hey have a good return policy in case its defective ....
#5 livinginkaos
Posted 02 September 2014 - 04:36 AM
I've heard not so good things about that site, look for reviews.
sent from my G3
#6 smb5769
smb5769
  • 30 posts
Posted 02 September 2014 - 06:17 AM
That's what I kinda figured. Twenty sounds too cheap. That's a hundred dollar battery if I remember right.
#7 johnthehillbilly
Posted 02 September 2014 - 06:21 AM
Which is why I would look (on eBay or swappa) for someone that has a broken phone and is possibly selling the useable parts...... Then its a better bet that you are getting a OEM battery and probably in decent shape...:)
#8 livinginkaos
Posted 02 September 2014 - 07:29 AM
I've had luck with Amazon as well.  The EV30 (Razr HD) is about $27.   The EV40 (Razr HD Maxx) is about $37.
#9 livinginkaos
Posted 02 September 2014 - 10:25 AM
Oh, and, I always try to buy OEM on batteries.  No need to have my phone explode :)
  • smb5769 likes this
#10 XE_Nerd
XE_Nerd
  • 193 posts
  • Current Device(s):DROID RAZR HD, HTC Rezound
Posted 02 September 2014 - 01:39 PM
I'm curious how your battery is bad?
#11 smb5769
smb5769
  • 30 posts
Posted 03 September 2014 - 09:08 AM
I'm not sure if I've let it go dead one too many times or if I use it too much. I had two and a half hours of screen time the other day with five and three quarter hours of on battery time and went from 100 to 2% in that time. It gets pretty hot while I'm using it. The battery info says that the battery is good though? I don't know.
#12 johnthehillbilly
Posted 03 September 2014 - 09:16 AM
You may want to try "calibrating" the battery...... Use it until it shuts off on its own...... Leave it off, plug into AC charger NOT USB plugged into computer when it shows 100%.... Leaving it on charge for an additional 1/2 hour to hour........ Use it until it shuts off again..... Charge again with AC charger(like above)
#13 livinginkaos
Posted 03 September 2014 - 09:29 AM
2-1/2 hours of screen time is nothing to complain about either really if you are stock and have your brightness set high.
#14 johnthehillbilly
Posted 03 September 2014 - 09:42 AM
You may also have an app or two running rampant in the background sucking down your battery......
#15 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 03 September 2014 - 09:51 AM
Google location services has been a major complaint for people lately.  I disabled mine completely, but there's also an Xposed module that can adjust the time that location services wake the phone.  I disabled location services on my M8 last week (I had done this previously, but I updated my ROM and it was re-enabled) and I gained quite a bit of battery life.
#16 smb5769
smb5769
  • 30 posts
Posted 03 September 2014 - 11:34 AM
Hmm. I have it set on auto. I just don't think I remember my phone going down that fast from 2-1/2 hours screen time. It's made it to 30% with that much screen the but its never gone to 2%. Maybe I need to recalibrate it.
#17 XE_Nerd
XE_Nerd
  • 193 posts
Posted 03 September 2014 - 01:26 PM
That's why I asked. It is likely an application using up your battery. Unfortunatly it's tough to figure out. I think I have it figured out and than something else starts eating up my battery. So far reverting back to JB stock has been the best thing for battery life which I'm not running right now. The last few days my phone was only using half my battery in a 12 hour time span and today I hardly used it and it died before I got home from work... something killing my battery again after updating some google apps. Right now apps have issues with KK keeping phones awake.
#18 smb5769
smb5769
  • 30 posts
Posted 03 September 2014 - 04:15 PM
Hmmm. Since I'm rooted and unlocked going back to JB sounds tempting.
#19 morrisr3nd
morrisr3nd
  • 33 posts
  • LocationMississippi
  • Current Device(s):Droid Razor Maxx HD
Posted 21 September 2014 - 06:55 PM
I have a OEM battery that came out of a bricked Maxx HD.
#20 snowman
snowman
  • 111 posts
  • LocationSparta, Tn.
Posted 16 October 2014 - 04:52 AM
if your running 4.4.2 that could be the problem I just went back to 4.1.2 and fixed my battery issues
that new update is awful battery hog to the max something is wrong with it
when I went to settings battery it always said media was my biggest battery burner with 4.4.2
now back on 4.1.2 that has quit and it says display again which is back to giving me many days out of battery?
my phone always felt very hot in my pocket before downgrading
Do it now you may not be able to later
