Bricked And Need Help Asap! While Battery Still Full!
Posted 24 January 2012 - 01:51 PM
I have downloaded MotoHelper_2.1.32_Driver_5.4.0
and the containing Zip files for the Fastboot, VRZ_XT912_6.5.1-73_DHD-11_TA-3_1FF_02.xml (file size is 2.76GB)
I have RSD Lite v5.6 installed and open. i chose the xml file, put my phone into AP FASTBOOT and plugged into my computer, and clicked start.
I end up with the following error, i have tried multiple times and it seems to fail somewhere along steps 12/18 and 9/18.... this is the reported error.
"Failed flashing process. Failed flashing process. 9/19 flash ebr "ebr"-> Size data returned by phone does not match what was expected.; phone connected.
I will enclose an IMG of the screen im seeing. Would really appreciate any help on this matter, as the battery is still full atm and i do Not have a factory data cable to charge once dead. Please some1 help me !!!!!! <3
247.3KB 24 downloads
EDIT** I AM IN CHAT ON THE SITE SO PLEASE HOP IN! THX
Posted 24 January 2012 - 02:26 PM
Posted 25 January 2012 - 01:02 PM
Posted 25 January 2012 - 01:31 PM
there is another method by using command prompt and doing it through there. its on the forums in here. lemme see if I can find it.I have the same problem.. What did you do to fix it?
Posted 25 January 2012 - 01:58 PM
http://www.droidrzr.com/index.php/topic/324-how-to-unbrick-your-razr-go-back-to-stock-full-fast-boot-files-added/I have the same problem.. What did you do to fix it?
^^ follow the steps above and all should be a go!!
