[Mod] Advance Power Menu and 1% battery for 183.46.14.xt926
Mod Reboot menu Advance Power Menu
11 replies to this topic
#1 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 11 September 2014 - 04:55 PM
What we got here is something that you can add on to the current Stock 4.4.2 183.46.14.xt926 update.
Advance Power menu allowing you to use without the need for Xposed framework, Also 1% display on
Status bar Battery monitor. There will be some additional addons to this section, but with the limit of
Time it will not be in a fast pace as normal updates. Hope that you enjoy...
Screen Teasers...
All things that I needed to accomplish these features
were found from below links. Thanks goes to these guys for these guides.
Battery Mods
Advance Power Menu
Installation Instructions.
ROM must be Deodexed......
Place update on internal Storage
Boot into Recovery
Apply update without any wipes.
Reboot into System and Enjoy......
The Goods
If you like my Work
  • Bama, j37hr0 and ka3boosh like this
#2 Bama
Bama
    Needs Beer
  • 582 posts
  • Locationsalem,al
Posted 11 September 2014 - 05:01 PM
1st
  • nobe1976 likes this
#3 livinginkaos
  • 15,105 posts
Posted 11 September 2014 - 05:03 PM
2nd
sent from my G3
#4 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
That you are
#5 N1smo
N1smo
  • 7 posts
Posted 15 September 2014 - 09:55 AM
I would like to flash this mod but I am using your rooted odexed ROM. Is there any way you can make a zip for us guys that went that route? Or I can just flash the deoxdexed rom, but isn't it for guys who themes and is actually slower?
#6 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 15 September 2014 - 04:10 PM
I will have to actually rework the updater script to delete the odex parts in order for this mod to work on that particular version. Running the Deodexed-Debloated version would be the best way to use this mod since there would be lest System and Bloat not running to make it run snappier.
  • Joseberga and N1smo like this
#7 ka3boosh
ka3boosh
  • 33 posts
  • LocationCalifornia
  • Current Device(s):Droid Razr XT926 HD
Posted 04 January 2015 - 11:05 PM
i flash the file at my phone nothing happen
xt926 HD android 4.4.2 kitkat
183.46.10
i flash the battery mod this mod work
any  idea how to make power menu work on 183.46.10
thank you
#8 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 05 January 2015 - 08:03 AM
183.46.10
thank you
Your stock side is still Odexed... If will have to be applied to a deodexed System. Or you will have to manually delete the odex counterparts to see this feature. After the deletion a reboot is a must.
Sent from my LG-VS980
#9 ka3boosh
ka3boosh
  • 33 posts
Posted 05 January 2015 - 04:41 PM
i went to system apps i delete all the odex files i flash the file using twrp no change happen
is there any odex files i need to delete it i search i didnt find any odex files on diff folders
#10 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • Twitter:@rlongjr80
  • LocationNoDak
  • Current Device(s):Pixel 5
Posted 05 January 2015 - 05:20 PM
It'll be easier just to flash a de-odexed ROM or de-odex the ROM yourself.
Sent from my HTC6525LVW using Tapatalk
#11 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 05 January 2015 - 05:43 PM
These are the Three odex files that will need to be deleted..
system/priv-apps/SystemUI.odex
framework/framework-res.odex (if its there)
framework/android.policy.odex.
I would seriously delete these using the built in file manager on TWRP. Make sure you mount system before going in and deleting ONLY those three. Flash the package again and wipe cache and dalvik after update installs. Then reboot and profit.
  • RikRong likes this
#12 ka3boosh
ka3boosh
  • 33 posts
Posted 08 January 2015 - 07:07 PM
These are the Three odex files that will need to be deleted.. system/priv-apps/SystemUI.odex framework/framework-res.odex (if its there) framework/android.policy.odex. I would seriously delete these using the built in file manager on TWRP. Make sure you mount system before going in and deleting ONLY those three. Flash the package again and wipe cache and dalvik after update installs. Then reboot and profit. Sent from my LG-VS980
thank you so much i deleted the files as you said using twrp file manager and mount the system the i flash the file plus wipe cache and dalvik it work 100%
good job
  • nobe1976 and cmh714 like this
Also tagged with one or more of these keywords: Mod, Reboot menu, Advance Power Menu
