I've searched everywhere but returned no results for the stock rom of a droid razr maxx hd. i'm looking to downgrade from the Jelly Bean leak.
Droid Razr Maxx HD Stock Rom
Playb3yond
, Nov 21 2012 11:05 PM
4 replies to this topic
Posted 21 November 2012 - 11:05 PM
- gregspruce likes this
Posted 21 November 2012 - 11:52 PM
wrong area your in the og razr forums, but go here to get back to stock razr maxx hd ics no problem.
p.s. if you looking for a flash-able rom there is only a jb leak rom so you will have to fastboot back to ics unless you wanna just ride out the jb leak.
those who mind don't matter, and those who matter don't mind.
Posted 23 November 2012 - 05:46 AM
Alright, thanks for the advice and it seems as though I've picked the most knowledgeable forum
Posted 26 November 2012 - 06:27 PM
Is there an alternative download link for the link to the xml file in the link you posted? The Jelly Bean leak doesn't support HDMI out ._. though I know it's a dev rom and quite a few things are missing
Posted 26 November 2012 - 11:58 PM
im confused xml file? if you follow those steps that leads you back to stable ics that has working hdmi the links are good and confirmed working.Is there an alternative download link for the link to the xml file in the link you posted? The Jelly Bean leak doesn't support HDMI out ._. though I know it's a dev rom and quite a few things are missing
