Help Motorola RAZR Maxx from Alltel
18 replies to this topic
#1 mettercomputers
mettercomputers
  • 6 posts
Posted 28 November 2012 - 02:53 PM
Can any one help with custom roms for the Motorola RAZR MAXX from alltel the info is below. Trying to find out how to make fastboot recovery files and flash working custom roms. Any suggestions would be great.
System Version: 6.16.300.XT908.ACG.en.US
Model Number : Motorola RAZR MAXX
Kernel Version: 3.0.8-ga0b5673hudsoncm@i93lnxdroid85_#1 SMP PREEMPT Fri Sep 28 07:22:18 CDT 2012
Build Number: 6.7.2-180_DHD-16_NA-30
Baseband Version: N_04.23.00R
AP flex version : GAS_NA_GCXSPYDERACG
Android Version : 4.0.4
Thank You to any and Help.
#2 mettercomputers
mettercomputers
  • 6 posts
Posted 29 November 2012 - 03:51 PM
No suggestion from anyone
#3 Jcubed
Jcubed
    Android Rescue Squad Leader
  • 131 posts
  • Google+:lovethelordjjj@gmail.com
Posted 07 December 2012 - 12:33 PM
most of the people here work with GSM or CDMA. I'm not so sure about what Alltel is :\ sorry bro
#4 johnthehillbilly
Posted 08 December 2012 - 04:31 AM
Part of Alltel wireless is owned and operated by verizon and uses the cdma network(s) (just so we all know that) :) ... given that you have a ICS maxx, i would say that some of the roms found here may work with your maxx..... however ..... and this is very important.... most of the work for the OG razr ICS and maxx ICS (xt912) done here (roms, utilities, themes, etc) are based on 6.16.211 for Verizon....... we are glad that you came here to look for "stuff" for your maxx..... will try to find out a little more information for you on this.....
#5 snives
snives
  • 947 posts
Posted 08 December 2012 - 05:13 AM
Just to add some more info... The hardware in the XT908 is supposed to be identical to the xt912, however the keys used are different. Being that Alltell and Verizon are the same company I would start off by finding someone you know with an xt912 and try swapping SIM cards. If that works, the prospect of fastbooting to an xt912 software might be worth considering. However, no xt908 files are known to have been leaked so it would be risky.
Rooting would still be safe I would think, but I'll defer to someone else because I've never looked into what exploit was used. Just don't Safestrap or try to flash anything without a trusted dev verifying it is not a suicide run.
#6 cole2kb
cole2kb
  • 20 posts
Posted 17 December 2012 - 11:43 AM
Check this out. I have an Alltel MAXX as well. I'll be updating my guide as things go and I explore more options.
#7 rickw
rickw
    corvette dude
  • 1,915 posts
  • Google+:rickwebb001@gmail.com
  • LocationDelaware
  • Current Device(s):S4 dev edition,moto x dev
Posted 18 December 2012 - 06:35 AM
great job,thanks for posting info
#8 chairwolf
chairwolf
  • 18 posts
  • Current Device(s):Motorola Droid Razr Maxx Xt908
Posted 23 December 2012 - 02:54 PM
I've got a similar situation. My XT908 is on nTelos, and has NO SIM card. It runs on a 3G network only; they are supposed to go to 4G/LTE in late summer 2013.
I'm looking for reliable root info on this. (BTW, I read that nTelos currently uses Sprint's network if that helps anyone help me figure out how to root.)
Here are the specifics:
ICS 4.0.4
firmware GAS_NA_GCXSPYDERNT
baseband version N_04.23.00R
Kernel version 3.0.8-ga0b5673
#1 SMP PREEMPT Fri Sep 28 08:23:00 CDT 2012
AP flex version GAS_NA_GCXSPYDERNT
Build number 6.7.2-180_DHD-16_NA-30
Need help from an expert to root this puppy!
Thanks, Bob
#9 cole2kb
cole2kb
  • 20 posts
Posted 25 December 2012 - 07:12 PM
Chairwolf, rooting should be the same process. I take no responsibility for damage to your device, but if you want to follow general instructions to install Safestrap 2.11, make a backup and send me the systemorig file that will reside in your backups folder, I can try to throw together a patch for you.
#10 pmassey31545
pmassey31545
  • 40 posts
  • LocationJesup, GA
  • Current Device(s):RAZR MAXX Alltel
Posted 27 December 2012 - 07:43 AM
Just so you guys know, I have rooted my Alltel Maxx with the EPRJ Easy Root and it worked great. Check out the following link-
I also installed safestrap and went through some ROM flashing but kinda got scared when I couldn't find an SBF for it. I did try CM9 (I think) and ran into a boot loop problem. Lucky for me I ddi a safe backup which saved me. I may play with it some more soon, But I am kinda timid ATM until I know of some way to get a bricked phone back to Alltel stock. Gonna play with Easy-sbf and sbf_flash when I figure them out and see if I can do it from there. Just don't want a brick......
#11 cole2kb
cole2kb
  • 20 posts
Posted 28 December 2012 - 07:00 AM
If I could get an SBF file, that would be ideal, but I'm not too worried about it. All I should have to do is uninstall Safestrap, and un-root to go back to "stock". I posted some flashable ZIP patches to make ROMs work with Alltel here, if you'd like:
#12 pmassey31545
pmassey31545
  • 40 posts
  • LocationJesup, GA
Posted 28 December 2012 - 07:50 AM
I have looked at that thread and downloaded the patches but I am just a little lost. I posted something over
for you to look at.
#13 chairwolf
chairwolf
  • 18 posts
Posted 30 December 2012 - 09:20 AM
Which one (from this link) do I use? I'm thinking spyder, but not sure.
thanks
#14 pmassey31545
pmassey31545
  • 40 posts
  • LocationJesup, GA
Posted 30 December 2012 - 05:40 PM
thanks
Spyder is the one I got but I am having trouble. Safestrap issues to be exact.
  • pmassey31545 likes this
#15 chairwolf
chairwolf
  • 18 posts
Posted 04 January 2013 - 06:23 AM
What kind of issues with Safestrap? Are you using the new SS, or 2.11?
#16 pmassey31545
pmassey31545
  • 40 posts
  • LocationJesup, GA
Posted 05 January 2013 - 11:55 AM
Actually got it taken care of.
I am now using 3.11.
#17 chairwolf
chairwolf
  • 18 posts
Posted 07 January 2013 - 04:47 AM
I'm a little confused. Can I install Safestrap BEFORE I'm rooted? If so, great, b/c then I can make a backup for Chris to look at. Soooo, will SS work prior to being rooted anyone?
thanks
#18 johnthehillbilly
Posted 07 January 2013 - 04:58 AM
thanks
No.... SS will not work prior to being rooted..... Sorry
#19 chairwolf
chairwolf
  • 18 posts
Posted 07 January 2013 - 05:56 AM
That's what I thought. Thanks, John!
