lownslowsx200 & vtwinbmx & prstorero & Rinkle & DDX
Fuzion HD
Full Release Daily Driver
This is a droidrzr.com exclusive do not post anywhere else!!!
Thanks goes out to the following people in no particular order
Hashcode - The Base
Tucstwo- Help with deodex
Thach- Wallpapers
Jaekar99- Boot Animation
Rinkle McBally- Wallpapers (Full Throttle Crew)
prstorero- Keyboard art and reboot menu ( Full Throttle Crew)
chainfire- Super SU
24v- Bluelight apk, keyboard help, Being a great Friend
travp624- Inverted contacts, play music, calendar, you tube
Gunthemic- Inverted talk,google now, play store,
MattlGroff- Adbd Insecure with remount and hosting the rom
Jrummel16- Start up tweak help and rom tool box free
dustinb17- the original Full Throttle Cobalt theme which is used in this rom
DDX- He the man! gave us this home and some cool new theme work!
nitro- toggles on ICS
Devortex- help when needed
- Battery Bar APK and Miui style battery bar
Nobody but you is responsible for what YOU DO TO YOUR PHONE! You take on ALL RESPONSIBILITY by flashing this ROM
ROM Features
Deblured
Debloated
Custom wallpaper
Custom Large Full Throttle Keyboard
Full Throttle 4.2 Keyboard
4.2 Inverted Gmail
Inverted AOSP Contacts and Phone
4.2 camera and gallery
AOSP inverted Calender
AOSP File Manager
Travp624- amazing inverted MMS with pop up and quick reply options as well as theme options
Inverted GTALK
Inverted Play
Inverted Google Now
Init.d support
Build prop Tweaks
Custom theme
reflective blue softkeys
1% Battery
You must be on Jelly Bean to run this rom
If you are unlocked you must mount system before flashing, flash boot img before rom
Install instructions
Download rom from link provided
Place rom on External SD card
reboot into safe strap
create a rom slot ( if you are running stock deodex rom in a slot you can flash over it)
Wipes- Full wipes, system, data, cache, delvik ( you been warned! )
Flash rom
Reboot
Set up your phone
Reboot
Enjoy!!!
Know issues
Status bar missing on first flash- Working on this to fix reboot after set-up
Download link:
Fuzion HD Rom:
MD5 CheckSum e6dcf6aa064877f9488094b5e8857e87
If you like to buy a beer to anyone involved in making this rom send them a pm to find out how
Don't forget to click the like button---------------------------------------------
