I am getting a lot of home screen redraws and the pattern lock screen seems a bit buggy as well sometimes I unlock my phone and its at the regular slider unlock and when I go from an app to the home screen everything redraws itself is that an issue that is known or should I flash back and take the ota
Hmm...I am not getting any of this...no redraws at all...but then again, I use Nova Launcher, as I prefer it over MotoBlur launcher...
Although I don't normally use lock screen patterns, I set it up to check for you, and not having any issues...but I do have a theory as to what you may be experiencing with the pattern...
In the security settings, you see where the setting for "Automatically lock" is?
(It's the third option down in security settings)...
it's default setting is set to "5 seconds after sleep" which means that if you turn your screen off, it will go back to the slider unless you wait 5 seconds...or you can change it as you please (including immediately)....also, you can check the next setting down "Power button automatically locks"...
