4.4.2 problems how do I go back?
21 replies to this topic
#1 snowman
snowman
  • 111 posts
  • LocationSparta, Tn.
Posted 13 October 2014 - 03:50 PM
well tried everything read first don't see how to go back on any other post
Droid Razr Maxx HD  XT-926
unlocked running 4.4.2
Battery is frying less then a day long actually feels very hot in my pocket
I'm unlocked but never ran any other rom's or anything like that
Question how can I flash back to 4.1.2
it was sweet and for my use it worked great this update is worse then horrible
lots of issues just hate it.
can I flash back?
thanks much guys and gals
Do it now you may not be able to later
#2 johnthehillbilly
Posted 13 October 2014 - 03:52 PM
Unlocked..... Go here
read read read read........ You WILL be able to downgrade
#3 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 13 October 2014 - 05:08 PM
can I flash back?
Question????? Do you plan on running Straight Stock ROM or do you plan on using Custom or Modded ROMs...
If the answer is the second one. Then Go
Read the instructions in the Post and please ensure that your Data Partition is back to Ext.4 format. If you don't know how to do so then go
The FlashBack.zip has the latest 2.8.0.0 TWRP included so You will not have issues connecting it with your PC and restoring any Data that is stored on your internal Storage. Also you will be able to load up any JBBL ROM through the MTP or USB connections.
Best regards...
#4 snowman
snowman
  • 111 posts
Posted 13 October 2014 - 06:07 PM
Thanks John and nobe I really appreciate it much
nobe I'd like to try some other Rom's just never learned how to do it ?
so I will just most likely go back to 4.1.2 it worked and well to me at least
I'll go play a while and let you know what's up thanks much again
#5 snowman
snowman
  • 111 posts
Posted 14 October 2014 - 04:49 AM
stupid question how do you know on this page which is the correct FXZ there are many 4.1.2
here is what it says
) The correct FXZ for your device from here:
been doing this for hours can't get it to work yet?
according to Sam I'm using rsd light and RSD flasher because I am using windows 7 to do this==not house of moto
my phone is a Droid Razr maxx HD I want 4.1.2 but there are many of these?  listed
#6 johnthehillbilly
Posted 14 October 2014 - 05:25 AM
Actually any one of them will be fine....
#7 snowman
snowman
  • 111 posts
Posted 14 October 2014 - 06:36 AM
Here is something john or node I'm having trouble with
USAGE:
o) Run the RSDFlasher.jar
o) Locate your SDL.exe file in your RSD Lite installation directory.  NOTE: This will only be necessary the first time you run.
I cannot find it anywhere I uninstalled RSD Flasher and tried to reinstall it but cannot it says it's already installed when I try and reinstall but it's not
but be hidden somewhere? looked in root for programs but don't see this folder anywhere to reopen the sdl.exe  file  the first time
#8 johnthehillbilly
Posted 14 October 2014 - 06:44 AM
It should be in C: program files (or program files(x86)
#9 johnthehillbilly
Posted 14 October 2014 - 06:46 AM
You may need to completely remove it (via control panel) reboot.... Reinstall
#10 snowman
snowman
  • 111 posts
Posted 14 October 2014 - 07:10 AM
That may be my problem it isn't listed in  the uninstaller to be able to uninstall it
or not in either one of those directories on the c: drive
pretty wild , there must be a trace of it somewhere so it will not install again
#11 johnthehillbilly
Posted 14 October 2014 - 07:13 AM
Hit start .... Type... run.... Hit enter..... Type %temp% ... Hit enter..... Delete everything in temp...... (A few things will say they are in use and can't be deleted... hit skip)..... Reboot..... Try again
#12 snowman
snowman
  • 111 posts
Posted 14 October 2014 - 09:41 AM
Crazy  I walked away as Sam mentioned in another post there is no rsd light info in the programs/x86 folder anywhere
did what you said on clearing temp files rebooted a few times still says it already exist when I try to install it again
maybe I'll try it on my wifes computer? about 5 hours still not able to simply flash pretty wild eh!
Thanks so much for trying to help though I really appreciate it
#13 snowman
snowman
  • 111 posts
Posted 14 October 2014 - 11:27 AM
John loaded everything on my wife's new computer
Java
Rsd light
Flasher
4.1.2 FXZ file
it worked on that on I'm back to 4.1.2
now just gotta load all those app and get all the setup done a dayswork
guess I need to block updating the firmware to 4.4.2 I guess with Titanium backup
Again   THANK YOU for all the help I appreciate it very much you to nobe
wow maybe my battery will last longer then 1 day and I can write to my 64 gig sd card again
#14 johnthehillbilly
Posted 14 October 2014 - 12:29 PM
Java
Rsd light
Flasher
4.1.2 FXZ file
Great... Glad you got it.... BTW... The updater could be "updater 4.x.x" or the "new" name "MotorolaOTA".... Search for both in TiBu whichever one comes up.... Freeze it (or delete it)
#15 snowman
snowman
  • 111 posts
Posted 16 October 2014 - 04:43 AM
John , just wanted to give you a follow up
battery on 4.4.2 was dead in about 8 hours before downgrade
yesterday 14 hours only used 13% on 4.1.2
and I can write to my external SD again and move apps to there
Great!!
also froze the updater
#16 vakharia
vakharia
  • 58 posts
Posted 05 November 2014 - 02:14 AM
@snowman: I read your other post and then discovered that you had created a new thread to go back to 4.1.2.
My dad's phone is not able to see the home wifi (but can see other wifi's around), though other devices in the house can see that home wifi.
This happened exactly one month after the upgrade.
After playing will all settings, and not succeeding, I think the only options are:
1. Factory reset
2. Downgrade to 4.1.2
I don't think he has complained about poor battery after the upgrade.
Question: Did you use HoM or RSD flasher?
Question 2: Do you know if the phone will get soft-bricked if we do a factory reset? The bootloader was unlocked long back (and during recent upgrade to 4.4.2, the phone lost root. I don't remember, but I think we have TWRP installed on the phone.
#17 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 05 November 2014 - 07:22 AM
1. Factory reset
  • vakharia likes this
#18 vakharia
vakharia
  • 58 posts
Posted 25 November 2014 - 03:05 AM
It has been a while since I updated.
The short answer to the WiFi problem is - factory reset.
You don't need any tools - just go to the settings and do a factory reset. The WiFi starts working after that (the version of Android remains the same, but we have to restore all our apps and the data (images/ videos/music/ etc) from our backup.
#19 snowman
snowman
  • 111 posts
Posted 01 December 2014 - 04:41 AM
Used RSd flasher. Should not hurt it at all to reset. Usually better should be done
#20 snowman
snowman
  • 111 posts
Posted 01 December 2014 - 04:42 AM
I just reloaded towel root to re- root
