Posted 11 December 2012 - 06:00 PM
Basically, f%$k modding it at this point. I just want my old mans phone to work properly again, I figured out a way to keep it powered down so that I can wait for a response and not kill the battery. Please help!!
Posted 11 December 2012 - 06:04 PM
I just signed up here because I need help fixing my Razr Maxx. I got this phone when my father had passed away and switched to it because of the battery life. Today I rooted and loaded JB onto my galaxy tab and got inspired to get it on the phone. cm-10.1-20121203-UNOFFICIAL-spyder-alpha is what I used. I did everything step by step rooting and then using the Razrtouchblack apk to get clockwork mod. Since everything it has just gone into the cyanogenmod loading screen for decades until I force restart into recovery and shut it down. I've tried clearing cache (twice as you all insist) and doing a factory reset and nothing. so then I tried flashing different roms including the official ics build. no dice, they get to a point where its working and then theres an error something about E: Failed to verify etc etc.
fastboot back to stock using matts utility. then start over.
Posted 11 December 2012 - 06:09 PM
Posted 11 December 2012 - 06:10 PM
Alright I will try this, thanks for the suggestion. ultilities downloading now **crosses fingers**
All else fails we set you up with rsd lite and the full fxz but matts utility rocks so it should do the trick.
Sent from my DROID BIONIC using Xparent ICS Tapatalk 2
Posted 11 December 2012 - 06:14 PM
And we are always here to help if you need it ?
sent from my DROID RAZR tapadriving ...
Posted 11 December 2012 - 06:22 PM
Which utility are you downloading.... i would recommend 1.82.... either windows or linux ..... your choice
+1
Posted 11 December 2012 - 06:27 PM
Posted 11 December 2012 - 06:28 PM
Posted 11 December 2012 - 06:31 PM
Glad you got it.....!!I used 1.82. Thank you all for the help. It's loading up now back to normal.
Posted 11 December 2012 - 07:01 PM
- Memnoch73 likes this
Posted 11 December 2012 - 07:05 PM
Posted 11 December 2012 - 07:25 PM
I know its probably really lame to say it, but you guys really helped me on a level you may not understand. This phone means a lot to me because I had suggested it to my father and helped him learn how to use it, it's one of the last tangible things I have left of his and I wanted to use it because as a nerd it just appealed to me. If I had bricked it I would have been really upset, and for a while today I was fairly convinced thats what I had done. Thanks again, clearly I've found a place for helpful information with learning all this, all my other droids have been htcs
Man that's some powerful stuff there. Thanks for sharing it with us. Glad we could help get you back up and running.
- johnthehillbilly likes this
Posted 11 December 2012 - 07:27 PM
For me it always feels good if i am able to help someone in need.... but this makes me feel even better
Posted 11 December 2012 - 07:30 PM
Posted 11 December 2012 - 07:31 PM
If you want to try CM10.1 on your RAZR, use Safestrap 3.05 and it should load up. 10.1 has some bugs so it may not be a good choice for your daily driver.
Posted 11 December 2012 - 07:37 PM
