1) I cracked my screen on my Droid RAZR and now my screen will not respond. I was wondering if there is anyway without using the screen I could make a backup of the current ROM and flash it onto my new one.
2) I have a new RAZR but I have a couple of issues. My WiFi Tether app (from googlecode v3.1beta14). It worked flawlessly on my other Droid but now it starts up and has errors and won't work. I decided to use PDANet and purchased the key to use it as much as I want. It connects to my PC and says it has Internet Access but it doesn't work. Any suggestions on Wi Fi problems? It's dreadful not having Wi Fi tether because it is my only means of internet.
Thanks in advance.
Couple of Questions. Please Assist!
JDunc
, Dec 08 2014 03:35 PM
1 reply to this topic
Posted 08 December 2014 - 03:35 PM
Posted 08 December 2014 - 04:05 PM
If there is clockworkmod recovery for your phone you use the physical buttons to control it so that'd work. As for the tether I'm not sure about that.
sig made by
Rinkle McBally
