Data Issue And Sometimes Not Receiving Calls
Posted 29 January 2012 - 10:33 AM
Now off to the issues, and they are major ones. I keep losing my data, and for long periods of time. I called Motorola [color=#812528 !important][color=#812528 !important]tech [color=#812528 !important]support[/color][/color][/color] and they had me download the "restore connectivity settings" app from the app store. It was supposed to fix the issues, and in the 5hrs since I downloaded it I lost the data 4 times (that I noticed). While holding for second level tech support I got hung up on twice. On the third call I was told they had left for the day. You would think they would have fixed this known issue before releasing a new phone! Does anyone have any suggestions?
I am also having trouble receiving all my calls. So far 4 times I have gotten random [color="#812528"][color=#812528 !important][color=#812528 !important]voicemails[/color][/color][/color] when my phone didn't ring. All 4 people said my phone just went to voicemail without ringing and I happened to be in an area with perfect service. Is anyone else having this issue too?
Jim
Posted 29 January 2012 - 10:59 AM
They will likely ask you to hard reset and do a power down and remove similar card and all that nonsense ... waste of time for 90% of issues bit that's just part of the troubleshooting process.
Since you just got your phone, DO NOT allow them to issue a "like new" replacement no matter what. It waives your 14-day worry free guarantee and at that point you can't take it back if your signal issues don't improve.
[ sent from _base2 ]
Posted 29 January 2012 - 02:54 PM
If you want you can upgrade the radio with my 6.12.173 leak. An info guide and installation guide can be found here:I got my Razr Maxx as soon as the Verizon store opened, I waited for the battery life after returning my original Razr. The battery is awesome, it actually does last all day!
Jim
It's helped fix data drops for me
