[Opinions] 98.72.8 Likes/Dislikes/WorkArounds
Posted 25 December 2012 - 11:47 AM
System Version 89.72.8
I, like many others, took the plunge without knowing much about it.
The only trouble I had installing it was getting SU to update binary on ICS after uzing DRU 2.81 to get back back to .211, I had been on .215
A quick SU app only data wipe got me back on track. Restored root on JB by following Matt's directions.
**BUT to get to the point of this thread, now that many of us are on it:
-What new features have you found?
-What changes do you like? Dislike?
-Are there known workarounds for any of our dislikes?
Getting these questions answered may help some decide if they want to take the plunge or not, and help out those of us who did.
Posted 25 December 2012 - 11:51 AM
Like: Transparent status bar on home screen
Smooth so far
Good signal so far
Dislikes: Flash not supported officially
Long pressing the search button now does the same thing as just pressing the search button. Google now. I used to long-press it as a shortcut to SoundHound, WidgetLocker, etc. *#*#INFO#*#* no longer works (Edit: it does if you are in the dialer from Phone but Not dialer from People which is what I was using)
Posted 25 December 2012 - 11:59 AM
Posted 25 December 2012 - 01:00 PM
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Posted 25 December 2012 - 04:23 PM
Matt said this wasn't possible... how did you do this?FYI:
I was able to update to this and then use Matt's utility to go back to .211 without a problem!
IT would be really nice if somebody would de-odex and repackage the OTA for SafeStrap.
Sent from Razr Maxx running Full Throttle Killer Bean
Posted 25 December 2012 - 04:36 PM
From the time i've had it and had the Rezound with ICS, this JB leak is soo much quicker between transitions, whether just scrolling the home screens or opening aps. Plus it all looks a lot cooler with the transition effects. It's all the speed and aspects of Jelly Bean I liked that I experienced when using the JB roms here, but i miss the customization. That will all of course come soon. Definitely worth the update
Posted 25 December 2012 - 05:00 PM
Smart actions is the version that does not let you turn off mobile data when WiFi is on … :-(
Here you go. This is the "good" version if smart actions. Flashable .zip
- thebluegod likes this
Posted 25 December 2012 - 05:03 PM
Posted 25 December 2012 - 05:11 PM
im Currently FB back to .211 using utility also no fails.
I wants me some screenshots please.
Posted 25 December 2012 - 05:23 PM
Posted 25 December 2012 - 05:25 PM
YES! I Also would like too know HOW you were able too Fastboot back? i was told it would not work and or it would mess up the phone?Matt said this wasn't possible... how did you do this?
Posted 25 December 2012 - 05:49 PM
Posted 25 December 2012 - 06:09 PM
Posted 25 December 2012 - 06:18 PM
I'm thinking it's just like a rom you need to calibrate the battery by letting it die and recharge completely before you will get good battery life. I got 4 hours on screen with about 12 hours off the charger and I was at 20% on a maxx so it's definitely not the best I've gottenAnybody got any good battery life so far? Im having so/so reviews on it so far...mine today barely lasted 8 hours before I had to put my Maxx back on the charger
Posted 25 December 2012 - 06:36 PM
I was told the CDT.Bin changes.
X
Posted 25 December 2012 - 07:17 PM
The transparent home screen status bar is something I've been waiting forever for. I also like the font and the new animations. I'll test battery life tomorrow.
Posted 25 December 2012 - 07:38 PM
It failed at boot.IMG prevalidation error. But I was able to get past brick booted back into recovery and upgraded via the package
Posted 25 December 2012 - 07:41 PM
How about these from my Maxx last night?
Posted 25 December 2012 - 08:02 PM
Also tagged with one or more of these keywords: 98.72.8, 4.1.2
