Motorola Circles widget & Lockscreen weather for OTA JB?
Posted 25 December 2012 - 09:12 PM
1) Is there any way to make the awesome Motorola circles widget work on the semi-official JB?
2) What about the lockscreen weather widget sort of like how Touchwiz has?
Would really love to get both of these working =)
Posted 25 December 2012 - 09:16 PM
you can get the circle widgets by installing the razr m launcher and circle widgets + the weather widgetInstalled the new JB update today (loving it), and just was wanting to find out a couple things.
Posted 25 December 2012 - 09:21 PM
Where can I get them? Thank you!
Posted 25 December 2012 - 09:58 PM
Posted 25 December 2012 - 10:05 PM
- tr1dent and ReSuReKtZ like this
Posted 25 December 2012 - 11:37 PM
I have these in a zip file. I found directions on XDA confusing. File I used is a zip, and has 4 apk's inside. I just installed apk's as normal. When I tapped "home", I got the usual choices (for installed launchers). I chose "launcher" as default, as I believe that is what this was called. Once selected, I installed circle launcher as i would any other widget. Didnt have to change anything. Very easy. Let me know if this is needed or wanted.....
YES! please! That would be much easier.
Posted 26 December 2012 - 12:31 AM
- most likes this
Posted 26 December 2012 - 02:27 AM
Posted 26 December 2012 - 04:28 AM
You're trying to use it with the stock launcher and that won't work. What APK's did you install? Assuming you've installed the 4 apk's you also need to use something like home switcher to switch to the Razr M launcher, then you can install the circles widget.circle widget not working for me. Says not supported by 3rd party home screens
Posted 26 December 2012 - 05:39 AM
Posted 26 December 2012 - 05:56 AM
Posted 26 December 2012 - 05:08 PM
Posted 26 December 2012 - 08:28 PM
Posted 28 December 2012 - 07:50 AM
Posted 28 December 2012 - 07:56 AM
Posted 28 December 2012 - 08:55 AM
Posted 30 December 2012 - 03:09 PM
RAZR M Laucher:
- Copy launcher to system/app
- Set permission to RW-R-R
- Tap on the the file just copied and do a double installation to overwrite system app
- Make a copy of homescreen.apk
- Change the .apk extension to .zip
- Extract using winrar or winzip
- Locate the files 'libnative_renderer.so' & 'libtexture_mem.so' inside the folder 'armeabi' under lib folder
- Copy both files to system\lib folder and overwrite any existing files and set permissions rw r r
- REBOOT
- Install 3d circles and weather in any order
Circle Widget 3D:
- Install as normal app
Weather:
Follow these directions and everything will work just fine!
Mike
- iMischief likes this
Posted 31 December 2012 - 06:35 PM
Posted 01 January 2013 - 01:30 AM
Ok guys i need some help. I deleted the old homescreen and homeconfig apk from system\app and installed the new razr m sht. I made backups on my ext sd of the system apps i deleted but now when i try put them back they wil go in the folder but will not install at all. What step do i need to do to make these old system apps overwrite the razr m stuff or just get back to as close to stock as i can get without fastboot? any help would greatly be appreciated
Move them back to the location you removed them from, set permissions to RW-R-R and tap to install.
Mike
Posted 02 January 2013 - 06:33 AM
- wabmorgan, SDPadre7 and mattkilla like this
