RAZR M Home Launcher & Circle Widgets For JB OTA RAZR
Posted 26 December 2012 - 02:17 PM
- jphillips.hd88 and grd069 like this
Posted 26 December 2012 - 02:52 PM
Edited by suckamucka, 26 December 2012 - 02:53 PM.
Posted 26 December 2012 - 03:23 PM
Posted 26 December 2012 - 04:37 PM
Posted 26 December 2012 - 04:41 PM
The link doesn't seem to work
It works, the first attempt to download failed at 13megs. I tried again and got the full zip.
Posted 26 December 2012 - 05:10 PM
Got everything installed and working except the live weather wallpaper. I don't see it under wallpapers / live.The stock weather it's in the zip.
Posted 26 December 2012 - 05:18 PM
OH... I thought it was a "live" wallpaper, i see it now under wallpapers. sorry for the confusion.Got everything installed and working except the live weather wallpaper. I don't see it under wallpapers / live.
Thanks for the files!
- dave5777 likes this
Posted 26 December 2012 - 06:07 PM
I have been trying for a few hours. The download link just doesn't work. I can open the page, but the download link on the page doesn't download.
Posted 26 December 2012 - 06:56 PM
Use this link. It is a zip file containing 4 apk files. Download link. Use file manager to open/unzip if needed. Install all 4 apk's, as you would any other apk. (Launcher/circles widget/weather/time). Once installed, tap "home". Should get a choice of which launcher to use. I chose "home" (other choices were Apex or Nova...).
Once I chose launcher, I installed widgets as i normally would. Very easy. No need to mess with permissions, change system apps to .bak apps, or anything else....
Let me know if this works....
Posted 26 December 2012 - 07:46 PM
Thanks for the link.
Posted 26 December 2012 - 08:31 PM
The Link in the OP works for me strange. The zip you posted doesn't have the CircleConfig.apk try this
Posted 27 December 2012 - 07:37 AM
Now that link is letting me download the file. Strange.
Posted 27 December 2012 - 07:48 AM
- hddeuce60 likes this
Posted 27 December 2012 - 08:37 AM
+1Force closes on GPS toggle.
Posted 27 December 2012 - 08:43 AM
Same here, Still better than the One more Clock widget.+1
Posted 27 December 2012 - 08:58 AM
Same...the best launcher....ever...
Posted 27 December 2012 - 10:03 AM
Posted 27 December 2012 - 10:04 AM
what is the tab on the left side of the screen with 3 arrowI was able to use the Razr M Launcher and Circle widgets on the 98.72.8XT912 OTA. Just Extract the zip use Root Explorer to install as System Apps. I backed up the apps I replaced on my sdcard. I would recommend deleting the old homescreen.apk and homeConfig.apk from the System\app.
Posted 27 December 2012 - 11:03 AM
http://db.tt/2Eju47hx
What Do I Uninstall If I Wish To Remove?
Edit: Nvm
Posted 27 December 2012 - 11:29 AM
swiping left should bring the Quick Settings screen. 3rd pic in OP
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
