Help with installing the JB Leak...
Posted 29 December 2012 - 08:18 AM
Sent from my Droid Razr Maxx running on high octane with Jelly Bean
Posted 29 December 2012 - 09:13 AM
Posted 29 December 2012 - 09:44 AM
Sent from my DROID BIONIC using Xparent ICS Tapatalk 2
Posted 29 December 2012 - 09:48 AM
Posted 29 December 2012 - 09:49 AM
Posted 29 December 2012 - 09:53 AM
Posted 29 December 2012 - 09:55 AM
he says something about "Know your battery" message... let me ask him exactly what it said
Ok thanks.
Posted 29 December 2012 - 09:56 AM
Posted 29 December 2012 - 09:58 AM
K he's said the message he got was "Know your device battery save" That's a new one on me after any kind of fail.
Is he trying to update with less then 50% battery? Might be a new failsafe on the leak. Tell him to charge it up and try again. I will look into it more.
Posted 29 December 2012 - 10:02 AM
if thought that too but when I flashed I was at 50% battery level and didn't realize it but I flashed with no problems..I'm just stumped why his phone won't flash, he even un installed SS
Posted 29 December 2012 - 10:21 AM
this is the fail message he's getting
Posted 29 December 2012 - 10:40 AM
Posted 29 December 2012 - 10:44 AM
Posted 29 December 2012 - 10:50 AM
Posted 29 December 2012 - 12:01 PM
I had the asset_failed.. apply patch check thing././..
Posted 29 December 2012 - 12:03 PM
Posted 29 December 2012 - 04:04 PM
I have ss3.07 installed on Fastbooted 2.11
Rooted, installed voodoo's ota root keeper,
protected root, temp unroot, restored, temp unroot, restored (I've seen on both the main page and Gytole's Ez guide that Root needs to be restored (NOT Temp unroot) before applying the update
The update keeps failing with-
assert failed: apply_patch_check("/system/bin/logwrapp
er","f39fcb2d78b9e92e9fbedc6a62a047dc23459416","4a63
fec78956def045b442910a754fa640db8f5a")
E:Error in /tmp/sideload/pacage.zip
(status 7)
Installation aborted
I don't want to wait for root to become available on JB, so i don't want to Fastboot and apply the update without protecting root first. Not sure if Root is necessarily the problem, but I've downloaded the update through 3 separate mirrors and have tried to apply the update with each of them, all resulting in failure. Any help would be greatly appreciated
Posted 29 December 2012 - 05:54 PM
Use matts utility to go back to. 211
Wipe all you can from the recovery screen in android menu
Apply update from external card
Wipe yet again.
Then reboot and that is what I did when I had same problem. Also used 2nd download of jb leak, but sorry I don't remember where it was from.
Good luck
Sent from my GT-P3110 using Tapatalk 2
Posted 29 December 2012 - 05:55 PM
Posted 29 December 2012 - 06:41 PM
Also I would recommend using the dual boot tool by xlightwaverx if still on ICS.
