No 4g LTE connection - stuck on EHRPD
Posted 30 December 2012 - 11:25 AM
I have two questions:
1. Is there any issues with doing a factory reset on the stock side considering I'm rooted and have roms loaded on slots 1 and 2. I wouldn't think there would be, but wanted to be safe before I do something like that.
2. Does anyone else have any other suggestions?
Thanks for the help in advance
Posted 30 December 2012 - 11:29 AM
For about two weeks I have not seen a 4g connection on my phone. I've tried multiple roms and even going back to stock and still no LTE. I've tried toggling back and forth from airplane mode, taking the sim card, and just simply rebooting the phone but every time it doesn't even attempt to connect to 4G. I've tried both Global and LTE/CDMA settings under mobile networks. I do get 3G with data with no problems. I do have the Network Signal app which tells me I am connected to EHRPD and I seem to be stuck on it. I called Verizon tech support and they told me the only other two things I can do is replace the sim card and do a factory reset. I asked them to send me a replacement sim card so I will try that first.
When you say you rebooted the phone, am I correctly assuming you rebooted with the SIM in it? If so, try taking the SIM card out and rebooting without it. Then when rebooted let it sit for 2-3 minutes, then power down, pop the SIM back in and reboot.
That might help. Lol.
HTC One M8 // 3.28.605.4 // CleanROM 3.0 w/HarmonKardon audio // Android 4.4.4
- "White Noise" out November 4th! (Recommended)
Posted 30 December 2012 - 11:41 AM
Posted 30 December 2012 - 11:59 AM
@chrisf I'm experiencing the same issue in a wide geographical area and other people have 4G when I don't.
Posted 30 December 2012 - 12:01 PM
@droidian just tried what you suggested, no luck.
Okay type the following into your dialer and post up a screenshot so I can see what the menu says: *#*#4636#*#*
Posted 30 December 2012 - 12:16 PM
Posted 30 December 2012 - 12:25 PM
@droidian here you go
Well everything's right.. I had this issue with my old HTC Rezound and I ended up getting a warranty replacement from Verizon. This may be what you will have to do unless anybody else knows anything else that may work. I don't off the top of my mind...
Posted 30 December 2012 - 02:34 PM
Sent from my SCH-I815 using Tapatalk HD
Posted 31 December 2012 - 07:43 AM
Posted 31 December 2012 - 07:46 AM
Posted 31 December 2012 - 11:15 AM
Posted 31 December 2012 - 12:21 PM
Factory data reset doesnt touch the system partition so root and safestrap will not be affected.
Correct. However, the safestrap apk will be deleted. Not the it matters if the safestrap recovery is already installed.
Sent from DDRMaxx using Xparent ICS Tapatalk 2
Posted 31 December 2012 - 12:25 PM
Yep very true.
Posted 31 December 2012 - 02:00 PM
