Rsd Has Failed Me....please Help
Posted 30 January 2012 - 10:27 PM
Posted 30 January 2012 - 10:31 PM
First wipe data/factory reset from the Motorola menu. RSD Lite 5.6 should always work unless you did something wrong in the guide or got a corrupt/incomplete download.... Download the update via Wi-Fi or Cell Data from 6.11.744 to get to 6.11.748, then install the upgrade .zip like in the 6.12.173 Installation Guide.Quick rundown rsd has failed me....i was able to download a file and sdk to get back to. 744 but now i cant ota to .748 my main objective is to get to. 173 so I can try out the "eclipse" rom. I have the files downloaded to flash my razr with rsd but rsd is not an option. Will somebody much more knowledgeable than myself walk me through/instruct my on exactly how to use sdk to install the updates??????many thank yous and my deepest graditude in advance.
Posted 30 January 2012 - 10:38 PM
Ive tried multiple different downloads of RSD, did the factory reset, used different data cables, and used two seperate XP machines all resulting in the same outcome.
Posted 30 January 2012 - 11:31 PM
Posted 31 January 2012 - 12:14 AM
+1 ThisWhat is it doing? Be sure to check to be sure the screen on the phone doesn't say battery low... It will fail every time then... I had to make a "factory" cable to charge while rsd to get back... I used the inards of my droid 1 dock and put the brown and red wire together... Then plugged inline with the usb cable I have and walla....
Also... when you say "RSD Failed" I need to know the details. What errors, what problems, etc. If you follow the guide word for word it works. If you can get TeamViewer I can try to make it work
Posted 31 January 2012 - 06:51 AM
IMO we need to know why or what error you are getting when trying to install the .748 OTA update.
Posted 31 January 2012 - 06:52 AM
Posted 31 January 2012 - 08:16 AM
Note: Im quite positive this is not a usb cable problem as every other razr/pc interface works, i can transfer files, use pda.net, charge...etc. The phone wont OTA update any attempt results in a failure.
Posted 31 January 2012 - 08:20 AM
Posted 31 January 2012 - 08:33 AM
Posted 31 January 2012 - 09:09 AM
Posted 31 January 2012 - 09:16 AM
Posted 31 January 2012 - 09:22 AM
Posted 31 January 2012 - 11:36 AM
Nothing is frozen about the only thing i can think of is that when i used kohlks "one click fastboot via command prompt" which is what got me to. 744 something got corrupted in my phones "stock" files. My problems with RSD began before that which is why i was exploring other options in the first place. battery levels are more than adequate.
Posted 31 January 2012 - 11:39 AM
Posted 31 January 2012 - 11:46 AM
Posted 31 January 2012 - 02:03 PM
Just to be on the safe side i tried again....did a full wipe, twice. Attempted an OTA update. Result: Fail
So are yu using rsd 5.6 with the appropriate drivers installed or are you using the 1-click script? That could obviously be a problem... rsd 5.6 should work.. you might wanna try updating moto drivers as well
Also, are you running as admin?
Without the error messages... there's not much we can do to help. That's like trying to get a car fixed over the phone by saying "it's not running right" ... the more info, the more we can do to help
[sent from the _base2 xoom]
Posted 31 January 2012 - 08:54 PM
understand.....the rsd errors are explained in pos t#8, the error when I try to ota goes by to fast (i am old with bad eyes and memory lol) I will try again and try to get a copy of the error. Here are the errors when I try the fast click.............So are yu using rsd 5.6 with the appropriate drivers installed or are you using the 1-click script? That could obviously be a problem... rsd 5.6 should work.. you might wanna try updating moto drivers as well
# Happy Flashing! #
ECHO is off.
Flashing BootLogo....
error: cannot load 'logo.bin'
Flashing EBR....
error: cannot load 'ebr_signed'
Flashing MBR....
error: cannot load 'mbr_signed'
Flashing DevTree....
error: cannot load 'devtree_signed'
Flashing Android System....
error: cannot load 'system_signed'
Flashing Kernel....
error: cannot load 'boot_signed'
Flashing Android Recovery....
error: cannot load 'recovery_signed'
Flashing CDR....
error: cannot load 'cdrom_signed'
Flashing Radio (BP)....
error: cannot load 'radio.img'
Flashing WebTop....
error: cannot load 'webtop_signed'
Erasing Cache....
erasing 'cache'... OKAY [ 0.036s]
Rebooting....
rebooting...
ECHO is off.
ECHO is off.
Greets from the EternityProject!
