battery issue
13 replies to this topic
#1 micka
micka
  • 17 posts
Posted 01 January 2013 - 02:45 PM
My battery gets low though i dont use it.. its getting low, and every morning i have to charge it coz its totally empty...sometimes i just turn it off at night so i dont need to charge in the morning...whats wrong with ds phone... the battery?... pls i need help...
#2 johnthehillbilly
Posted 01 January 2013 - 02:50 PM
Are you stock? Or custom ROM? ... ICS or JB ? .... do you have any apps that are running constantly ( that you know of?)
Is your WiFi on and connected?
Sorry if it seems like a bunch of questions but gotta start somewhere local :)
sent from my JB RAZR tapadriving
#3 micka
micka
  • 17 posts
Posted 01 January 2013 - 03:08 PM
I dont know any of it...:( i just did mmmmm apps that customize myphone... like keyboard and live wallpaper...:(
#4 micka
micka
  • 17 posts
Posted 01 January 2013 - 03:09 PM
My wifi is on...
#5 johnthehillbilly
Posted 01 January 2013 - 03:18 PM
OK.... I'm assuming you are stock so.... :) anyway... leaving your WiFi , Bluetooth, GPS, etc on can seriously impact battery life.... so can some live wallpapers... maybe try turning some of the things off when not using them... might help :) .. also go to menu/settings/battery and you can see what has been eating your battery... maybe take a screenshot of the battery stats screen and post it here.... :)
#6 micka
micka
  • 17 posts
Posted 01 January 2013 - 03:40 PM
until now i dont know how to take screenshot here in moto pls teach me....and how can i upload it here?..
#7 johnthehillbilly
Posted 01 January 2013 - 03:52 PM
Taking a screenshot is actually pretty simple.... :) you just hold power and volume down for a couple seconds... you will hear the camera shutter sound and save the screenshot to your internal sdcard.... I don't remember the limitations on uploading photos for new members ..... but you can feel free to email it to me at johnthehillbilly@gmail.com .... and I can look at it to try to help you figure out what's eating your battery.... and if need be I can post it here so someone smarter than me can also help :)
#8 micka
micka
  • 17 posts
Posted 01 January 2013 - 03:53 PM
Oh my... screen...is 79%...
#9 micka
micka
  • 17 posts
Posted 01 January 2013 - 03:57 PM
Oh thank you...it works...:) ill send the pix on your email...
#10 micka
micka
  • 17 posts
Posted 01 January 2013 - 03:59 PM
Pls check ur email
#11 johnthehillbilly
Posted 01 January 2013 - 04:07 PM
OK.... I got the pic..... looks like your screen is using up most of the battery which is actually typical for our razrs.... maybe try reducing your brightness and reducing screen timeout in menu/settings/display.... I have mine set at 10 % brightness and 30 second timeout..... its not a cure all but it should certainly help..... my battery life is not very good at all either but in a days time mine usually has only about 2 hours idle time :)
#12 micka
micka
  • 17 posts
Posted 01 January 2013 - 04:21 PM
Thank you so much...:)
#13 johnthehillbilly
Posted 01 January 2013 - 04:31 PM
You're very welcome.... anytime.... I hope it helps you out...:) also feel free to add me on gtalk (same email address) as well I'm usually on either here or gtalk (or both)
Always here to help (if I can) :)
#14 micka
micka
  • 17 posts
Posted 01 January 2013 - 05:03 PM
Ok...tnx: ))
