Acid Audio Engine
zero
, Jan 03 2013 03:10 PM
10 replies to this topic
Posted 03 January 2013 - 03:10 PM
If anyone hasn't tried this it's worth checking out. I flashed the v5.0 with no problems. I flashed a new ROM (JB kernel) and flashed new v6.0 and with the new version I have no sound. Any ideas?
- canezila likes this
Posted 03 January 2013 - 03:42 PM
I love the AC!D audio mod.
I messed up my first attempt at JB that had root when I used the AC!D mod... but I think it was something I did (or didnt wipe) that created the problem. I know I have seen ROMs with JB + AC!D so I know it works together. The fact you flashed 6.0 makes me jealous !!! hahahah I miss my rooted abilities. I will be interested to see how things go with your JB and v6.0... Hope you get your audio back soon. Sorry I dont have any help for you.
Posted 03 January 2013 - 03:48 PM
I just went back to 5.0. There's so many changes in each version it just keeps getting better and better.
Posted 04 January 2013 - 06:48 AM
I have been using V5.0 w/ Walkman for a few weeks and love it. As far as I know they have only released 6.0 for Xperia, though there are some ports currently being developed for other phones.
Posted 04 January 2013 - 10:57 AM
That's what I figured. I keep checking for a universal version.
Posted 04 January 2013 - 11:15 AM
So can we use 5.0 with our razr ? I'm running evolution 1.2 jb it will flash right?
Posted 04 January 2013 - 02:09 PM
I am using 5.0 with R3ds new ROM. It seems to work just fine.
- luke61456789 likes this
Posted 04 January 2013 - 02:26 PM
If you flash the 5.0 universal zip it will work. Just make sure the changes were made to build.prop after flashing.
Posted 04 January 2013 - 04:38 PM
Yes. The walkman works great by itself, better though if you flash the universal acid engine first. Then you may need to mod the build.prop in order for the acid engine to work properly.
I know I had to
Maybe this thread should be in RAZR apps instead of General
I know I had to
Posted 04 January 2013 - 05:56 PM
What do I have to mod in the build prop
Posted 05 January 2013 - 05:00 AM
I will not post a direct link, but all the info is at xd@ forum in thread titled "ACID Audio Engine™◄● |v5.0| ALL DEVICES (ICS+)"
