ADB problems on JB leak
Posted 13 January 2013 - 12:35 PM
Posted 13 January 2013 - 12:54 PM
Posted 13 January 2013 - 12:56 PM
Posted 13 January 2013 - 12:59 PM
Yeah, tried all that besides the factory reset, which I'm hesitant to do since this issue has persisted across the leaked JB update and several roms i was running while i was on the ICS kernel.
I can understand the hesitancy. Has adb worked at all for you on that computer?
Posted 13 January 2013 - 01:14 PM
Posted 13 January 2013 - 01:21 PM
Posted 13 January 2013 - 01:34 PM
Well if you rooted your nexus 7 the drivers for it must be up to date. Have you tried typing in adb devices and see if either of them pop up. Do you have your path set to the right directory? If you didn't add it to your path are you changing the directory to were adb is located?
I never changed my path, but i always open my command prompt in the platform tools. When i type adb devices, both devices show up as "device", but inside of a shell i get that my Razr shows up as offline. If i do the same with the nexus 7 plugged in, and inside of a shell it shows nothing and just goes back to "root@android". I rooted the nexus when it was on 4.1.1, however, and flashed all updates through clockworkmod, so maybe the nexus drivers are out of date. I'll try updating them.
EDIT: Drivers were up to date. Re-installed anyways, no effect.
Posted 13 January 2013 - 01:42 PM
Posted 13 January 2013 - 01:49 PM
Posted 13 January 2013 - 01:55 PM
Posted 13 January 2013 - 01:56 PM
While RAZR was plugged in did you try the adb kill-server? And after that did you do adb start-server?
I did, but ther weird thing is ADB does recognize the phone, it just thinks its offline. When i type "adb shell", it gives me "shell@cdma_spyder". It also won't let me cd anywhere, it gives me "/system/bin/sh: cd: Permission denied" when i try to cd /sdcard. This doesn't happen on the Nexus.
Posted 13 January 2013 - 01:57 PM
Also try using terminal emulator on your RAZR and type adb usb then hit enter and try adb commands from computer.
This gives me "error: device offline" in the terminal emulator.
Posted 13 January 2013 - 02:00 PM
1. make sure the device is set for usb debugging 2. Have the adb client running (e.g. via "adb usb" or adb start-server" 3. LEAVE the device connected via usb!!! 4. AND THEN reboot the device.
Posted 13 January 2013 - 02:09 PM
Wow OK now I am stumped lol. Last thing to try before I need to sleep on it lol.
After doing this i can now cd to sdcard, but i still can't do anything such as "adb remount", it gives me "error: device offline", and it still shows as offline if i type "adb devices" when in a shell.
Posted 13 January 2013 - 02:17 PM
Posted 13 January 2013 - 03:24 PM
Hmm I might have to look a bit more into it. A little progress but not enough. I will get back to you if I think of anything else. Maybe a computer wizz from here will chime in and save the day lol.
maybe i missed it but are you on a custom ROM?....stock?..... if you have safestrap installed try installing a ROM and or a different ROM and boot up normally, enable USB debugging and try again see if it recognizes it then....... also.... maybe try updating your adb by clicking "SDK manager" in the android adb folder..... (there is a new version of adb tools and platform-tools available)
Posted 13 January 2013 - 05:16 PM
The RAZR is stock, nonrooted Jelly Bean leak. I lost root after bricking on the leak, and had to downgrade to .211, get into stock recovery and reapply the update. And i actually just updated SDK stuff earlier today.
Posted 13 January 2013 - 05:27 PM
hmmmmmm....... ok... i will try to find out more about this for you.... my best guess (off the top of my head) is the adb part of the firmware on your phone is corrupt or has been damaged.....
Posted 13 January 2013 - 06:12 PM
