ADB problems on JB leak
#21
Posted 13 January 2013 - 06:21 PM
#22
Posted 13 January 2013 - 06:26 PM
#23
Posted 13 January 2013 - 06:54 PM
When you do adb devices does a serial number pop up?
Yes, i get a serial number.
Just a quick thought. I think adb remount command requires the device to be rooted. Maybe John can confirm or deny that.
Even if it's just /sdcard, and not /system?
#24
Posted 13 January 2013 - 06:59 PM
I'm thinking the remount cmd is only for the system partition.
#25
Posted 13 January 2013 - 07:08 PM
#26
Ah okay, that explains why i'm denied permissions when i use that command. Would you happen to know the correct command to mount /sdcard as r/w? All of the commands i turned up with a google search give me errors, and i just want to ensure i'm at least using the correct one.
#27
Posted 13 January 2013 - 07:09 PM
At any point did you have both devices plugged into the computer at the same time while trying adb?
Yes, both are recognized as "device" outside of ADB shell. Serial numbers are shown for both.
#28
Posted 13 January 2013 - 07:13 PM
#29
Posted 13 January 2013 - 07:15 PM
#30
Posted 13 January 2013 - 07:19 PM
#31
Posted 13 January 2013 - 07:24 PM
#32
Posted 13 January 2013 - 07:28 PM
adb -d shell is the cmd I'm thinking of. Should direct it to the device plugged in and start adb shell.
It gave me "127: shell@cdma_spyder". Is this what it is supposed to do?
#33
Posted 13 January 2013 - 07:30 PM
yes by the way... remount command generally requires root access.....
#35
Posted 13 January 2013 - 07:37 PM
That 127 is a command not found code. I'm rusty and apologize. Gonna try a simple one...
Adb shell
Reboot
If your phone reboots its recognizing adb, if not we got more digging to do lol.
#36
Posted 13 January 2013 - 07:39 PM
thanx tmyinc for stepping in and helping as well...... i'm old and slo LOL... trying to research this
You and me both lol. I'm so rusty with adb I could kick myself. I need to freshen up on it so this helps actually.
#37
Adb shell
Reboot
Returns "error: device offline"
#38
Posted 13 January 2013 - 07:41 PM
Yep more digging to do then. Between the 3 of us we will get it!
#39
Posted 13 January 2013 - 07:44 PM
#40
Posted 13 January 2013 - 07:45 PM
