My phone is going to the fastboot flash failure screen each time i reboot. I can hold in all 3 buttons and boot normal. I have to do this everytime i reboot the phone. This was caused by me trying to fastboot back to ics from jb after realizing I lost root and the flash failing. I am on the ota jb leak w/ root(thanks to dan). I think i just need to successfully flash any fastboot file. Ive read numerous things on this for the bionic but not sure if the files i need to fix this are available yet for jellybean. Can someone smarter than me give some advice?
Fastboot Flash Failure after reboot
balla48801
, Jan 15 2013 03:54 PM
5 replies to this topic
Posted 15 January 2013 - 03:54 PM
Posted 15 January 2013 - 04:01 PM
Confirm with someone else first, but myself I would fastboot .211 twice in a row, then try to re-install the JB update from stock recovery. It will fail to have a functional ICS, but the goal would be to just trick stock recovery into thinking you were on ICS still to get an on-path stock update.
Posted 15 January 2013 - 04:09 PM
I think I've heard of people flashing a boot logo via the fastboot screen in order to fix the failure.
Posted 15 January 2013 - 04:55 PM
alright yes flashing a boot logo via fastboot fixed it. thank you very much
- tmyinc likes this
Posted 15 January 2013 - 05:04 PM
You're very welcome. Happy to help.
Posted 05 February 2013 - 10:34 AM
Please I have the same problem with my Xt928. How do you flash the boot logo>alright yes flashing a boot logo via fastboot fixed it. thank you very much
