Posted 10 September 2015 - 06:59 PM
even with temp root, you can adjust your build.prop to make it fly. I use esfile explorer since it has root explorer and an editor in one. Just know that if you screw something up, not being unlocked, you may softbrick requiring a reflashing of the system partition. You would adjust the line that says net.tethering.noprovisioning=false to net.tethering.noprovisioning=true . You also need to rename the files in system/priv-app VZWEntitlementServices.apk and VZWEntitlementServices.odex to VZWEntitlementServices.apk.bak and VZWEntitlementServices.odex.bak Restart the device and you should be good.
Sig by
