Custom Boot Logos - Droid 3, Droid Bionic, Droid Razr, Droid 4
31 replies to this topic
#1 mhous33
mhous33
  • 480 posts
Posted 09 February 2012 - 10:41 AM
Had to search around a little to find out how to make and install custom boot logos so thought i'd put together all the info in one spot...
instructions are essentially the same for gimp and photoshop:
create a 540x540 image
merge into one layer
Gimp: select Colors > Components > Channel Mixer
Photoshop: select Image > Adjustments > Channel Mixer
select Output channel: Red and change the red value from 100 to 0 and the blue value from 0 to 100
now select Output channel: Blue and change the red value from 0 to 100 and the blue value from 100 to 0
hit OK
Note: the colors will look strange but will display properly on the phone
Gimp: select file > export
name "logo.bin"
select "all files" from dropdown menu
expand the "select file type (by extension)" menu and select "raw image data"
export
Photoshop: select file > save as
name "logo.bin"
format "photoshop raw"
save
flash your logo with fastboot:
code;
fastboot flash logo logo.bin
Thanks to p3droid and TBH!
  • mattlgroff, fbriceno97 and altspeed like this
#2 mopar57
mopar57
    Developer/MOD
  • 375 posts
Posted 09 February 2012 - 11:47 AM
I suppose that your talking about replacing the "M" logo?
because the stock razr boot-animation picture size is 540X960
Nice write up :)
Got an idea for a theme?
PM me!
I like mail! :D
#3 mhous33
mhous33
  • 480 posts
Posted 10 February 2012 - 11:59 PM
Yes this is for the initial splash logo, not the bootanimation.
#4 W0017roid
W0017roid
  • 128 posts
  • Twitter:17akota
  • Google+:17akota
  • LocationNorth Carolina/Pennsylvania
Posted 04 March 2012 - 06:32 PM
Maybe a Windows tutorial? or someone that could make a Safestrap/Bootstrap flashable .zip?
#5 mhous33
mhous33
  • 480 posts
Posted 04 March 2012 - 07:01 PM
*removed*
#6 DarkestSpawn
DarkestSpawn
    Tester
  • 211 posts
Posted 05 March 2012 - 05:25 AM
I posted one for Windows with photoshop based off P3 and you (mhous33) over at our sister site mydroidworld.com
-Beta Mod-
-Grand Master of the Testing-
#7 mhous33
mhous33
  • 480 posts
Posted 26 March 2012 - 08:59 PM
*removed*
#8 suicidetuna
suicidetuna
  • Google+:suicidetuna
Posted 21 June 2012 - 06:06 AM
if i have a boot logo that works on a Bionic, will it work on a Razr Maxx?
#9 mhous33
mhous33
  • 480 posts
Posted 07 October 2012 - 02:42 PM
updated op with new instructions. now works on gimp (linux and windows) and photoshop.
#10 altspeed
altspeed
    Director of National Stupidity
  • 654 posts
  • Twitter:@Pat_Droid
  • Google+:+Patrick Robinson
  • LocationDallas Texas
  • Current Device(s):RIP 8 & 16 GB Bionics, XT912 RAZR Maxx, XT907 RAZR M Current XT 1060 Motomaker Future Nexus 6
Posted 10 October 2012 - 07:51 PM
hit OK
name "logo.bin"
export
name "logo.bin"
save
drop your custom logo.bin into the update.zip:
XT862:
XT875:
XT894,XT912:
and flash in custom recovery
Note: The included logo.bin is og "hellomoto"
Just the little rectangle with the circles and the "hello moto" letters, like on say an old V220 or V400? That's very very cool.
  • mhous33 likes this
"We are the People Verizon warned you about"
8 GB Bionic JB, 16 GB Bionic JB, Bionic Lapdock X2, Razr Maxx XT912 JB, Razr M XT907 JBLX
#11 mhous33
mhous33
  • 480 posts
Posted 10 October 2012 - 08:34 PM
glad you like it, thanks! probably not alot of people who remember it from back in the day :)
#12 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
  • Twitter:@DarkOverDroid
  • Google+:DarkOverDroid@gmail.com
  • LocationMobile, Al
  • Current Device(s):DROID RAZR MAXX HD, DROID RAZR MAXX, iPhone 4, Galaxy Tab 2 10.1 (WiFi) 7" Acer Iconia Tab A-100 (Wifi)
Posted 10 October 2012 - 09:50 PM
Haha, I remember it! Thanks, this is sweet. I still have 2 E-815`s with this boot logo. :huh:
#13 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 10 October 2012 - 10:15 PM
Hey are you sure you can flash this in recovery for the xt912 RAZR? I was under the impression that you needed to use fastboot to replace logo.bin with the new one
#14 mhous33
mhous33
  • 480 posts
Posted 11 October 2012 - 12:33 AM
yeah e815 is classic :)
#15 mhous33
mhous33
  • 480 posts
Posted 11 October 2012 - 12:36 AM
fastboot is one way, dd is another way.
#16 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 11 October 2012 - 12:55 AM
Hey are you sure you can flash this in recovery for the xt912 RAZR? I was under the impression that you needed to use fastboot to replace logo.bin with the new one Sent from my DROID RAZR using Tapatalk 2
No, if you flash this through recovery on your Razr, it will throw your phone into fastboot mode with boot failure. You will be calling Batman to save your Razr.
#17 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 11 October 2012 - 01:20 AM
What would we do without batman :lol:
#18 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 11 October 2012 - 01:48 AM
Have enough bricks to build a house. lol
#19 mhous33
mhous33
  • 480 posts
Posted 11 October 2012 - 06:34 AM
i don't have a razr so I can't say for sure, but it should work the same way as with d3 and bionic which I know both work.
If for whatever reason it doesn't work, fastbooting the stock logo.bin would fix boot failure, but that would happen only if there is security / signature check on the mmcblk1p10 partition; and if there was, then fastbooting a custom logo would cause boot failure also, which we know it doesn't.
#20 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 11 October 2012 - 08:21 AM
Yea, It throw'd my Razr into fastboot with the boot failure. I flashed it through the safe side, don't know if it makes any difference. I just used RSD and FB back.
