Case That Fit's Razr Car Dock
Posted 15 November 2011 - 08:19 AM
#2 Guest_Jolly_*
Posted 15 November 2011 - 08:21 AM
Anyone successfully find a case that works with the car dock I originally bought the otter box (of course that didn't work) returned it for one that says it fit's dock and vehicle mount and it still doesn't fit! Am I missing something - or just need a case or are they non-exisitant
If they have the full body Invisisheild availablet that would be your only option. The car dock isn't designed to be used with a case.
Posted 15 November 2011 - 08:24 AM
Figured that much but it says on the box, fit's with selected cases; and the cases say fit's vehicle mount Oh well I'll look online, then just go caseless if needed.
Posted 15 November 2011 - 02:34 PM
- nakedgoat and jb_alphamale like this
Posted 15 November 2011 - 02:41 PM
I'll look before I leave work; and report back with findings!
- jayrod likes this
Posted 15 November 2011 - 02:49 PM
I didn't see any insert! But I'll look again! thanks A lot this things driving me nutz since it like you said, says it fits!
It doesn't really look like it's there, but you'll see that there is what looks to be two pieces of plastic together. You have the official motorola one, right?
Posted 15 November 2011 - 03:51 PM
Posted 15 November 2011 - 03:53 PM
Posted 15 November 2011 - 05:09 PM
Thanks works great dont know that the otter would fit, my high gloss fits nicely thanks again
Posted 15 November 2011 - 07:36 PM
Posted 15 November 2011 - 07:38 PM
Posted 16 November 2011 - 03:00 PM
Posted 21 December 2011 - 04:12 PM
Here is a link to a thread I posted some pictures of the Verizon Shell/holster, it fits in the car dock. It was a bit loose, so I put a small piece of adhesive felt at the base of the dock to take up the space.
Which car dock are you using with this?
Posted 22 December 2011 - 08:45 AM
This is the Motorola Razr specific car dock, from verion.
Posted 16 February 2012 - 01:39 PM
Oddly enough the original RAZR car dock has a removable insert. I ordered mine the same as you hoping to use my holster/combo in it but it does not work. And you are right, it clearly said it was compatible with most cases right on the box.
I am looking into a skin for it and hoping for there to be a straight holster for the MAXX someday. Then I'll have the skin, holster and the phone will fit right into the car dock.
Posted 16 February 2012 - 02:33 PM
:-D :-D
Posted 16 February 2012 - 10:06 PM
Posted 20 February 2012 - 06:25 AM
For anyone who might wonder about the Maxx car dock being used with a case, I received my dock today and there's no removable insert or way to insert the Maxx with any kind of case. So for me the only option is to use an easily removable case & take it off each time - bad design Moto.
I agree. I was figuring the MAXX dock would work exactly the same as the standard RAZR dock. There are inserts on both the docks and the mount for the RAZR. The MAXX mount, not so much.
I wish they would come out with a straight standard holster that fits the phone with no case on it. I want to use only a skin/protector AND carry it on my belt.
Posted 31 March 2012 - 07:20 PM
Posted 03 April 2012 - 04:37 AM
