Blurry Maxx v3.8
Roms
18 replies to this topic
#1 bpambrose
bpambrose
  • 35 posts
  • Current Device(s):Bionic, TFT700
Posted 27 January 2013 - 10:03 AM
Flashed Blurry Maxx v3.8 couldn't be happier or more impressed. This is a very solid Rom fast, stabile, my new daily driver. I have a renewed interest in my phone. Looking to make a donation to it's developer as soon as I find out where to make it.
#2 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 27 January 2013 - 10:17 AM
Glad you like it. I ask that all donations go to Hashcode, since he is the real reason that any of this can even happen. Thanks.
  • mrlolli likes this
#3 bpambrose
bpambrose
  • 35 posts
Posted 27 January 2013 - 12:31 PM
Thanks I will donate to Hashcode you developers deserve it thanks again.
#4 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
  • Current Device(s):xt926
Posted 07 February 2013 - 09:20 AM
Can Blurry Maxx v3.8 be flashed to a Bionic?
If so, is there a 'how to'?
dlw
#5 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 07 February 2013 - 10:16 AM
No. If there is a BIONIC port / version of {any} ROM it will specifically say so in the BIONIC section.
#6 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 07 February 2013 - 10:23 AM
For this ROM there *IS* a BIONIC port:
#7 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
Posted 07 February 2013 - 01:06 PM
Thanks,
The instructions say to use Safestrap v3.11
The only one I can find is Safestrap RAZR-D4-BIO-3.11.apk.
When installing via adb install this happens:
dlw@dlw-HP:~$ adb install ~/Down*/apk/Safe*.*
2148 KB/s (4632217 bytes in 2.105s)
pkg: /data/local/tmp/Safestrap-RAZR-D4-BIO-3.2.11.apk
Failure [INSTALL_FAILED_OLDER_SDK]
dlw@dlw-HP:~$
The same with v2.11.
Any ideas?
dlw
#8 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 07 February 2013 - 01:23 PM
Thanks,
dlw@dlw-HP:~$
Any ideas?
dlw
Just put the file on your sd card and install it through any file explorer app
#9 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
Posted 07 February 2013 - 01:54 PM
Downloaded Safestrap v3.11 RAZR** three times,
installed it three times via root manager as root.
got an 'parsar error' all three times.
Can 'bootstrap' be used?
#10 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 07 February 2013 - 02:13 PM
Better if you use SafeStrap.
Use
grab the official release.
And it is an .apk - just install it like any other .apk. Try downloading it directly via your phone.
If you have a bootstrap installed, you'll need to uninstall it (after uninstalling the bootstrap recovery from within the bootstrap app).
#11 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
Posted 07 February 2013 - 03:54 PM
Downloaded three times to phone:
Installed,
'parsar error'
deleted
redownloaded.
Same thing all three downloads
Didn't see any way to sign up.
Maybe I missed it.
#12 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 07 February 2013 - 04:13 PM
Don't need to sign up - I'm assuming you're on a BIONIC? If so, that .apk should work perfectly fine.
#13 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
Posted 07 February 2013 - 04:16 PM
Yes, I am on a Bionic xt875.
And, it does not work.
Will 305 work?
#14 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 07 February 2013 - 04:18 PM
might, but 3.11 is much better. The fact that you cannot side load an .apk is of more concern right now.
Have you tried downloading it with a computer and then copying it to your phone's SDCard?
On the phone, are you using the stock browser or a third party browser?
#15 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
Posted 07 February 2013 - 04:26 PM
Downloaded from three different places now.
Tried copy/past and dragging to phone.
Downloaded directly to phone.
Using 3rd party browser.
will try google.
#16 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 07 February 2013 - 04:27 PM
Use hte phone's built in native browser.
#17 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
Posted 07 February 2013 - 04:32 PM
Used built in browser.
Via google,
Same thing,
Parsing error
#18 dlw
dlw
  • 96 posts
  • LocationAmboy, WA
Posted 07 February 2013 - 05:19 PM
Earlier you posted:
I can install apk's all day with adb install.
There are several installed this way on the phone now.
Just not this one.
#19 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 07 February 2013 - 11:17 PM
That is weird then. That one .apk is not installing. I wonder why?
Sent from my Infinity using Tt HD
Also tagged with one or more of these keywords: Roms
