xt875 will not boot
Posted 04 February 2013 - 06:30 AM
Didn't see how to delete this second post, my apologies.
Had dealer flash phone to Page Plus.
Rooted and used phone for a few days deciding if to upgrade.
Followed video and installed Bootstrap; went well.
Mistakenly tried to flash an 'Infuse 4G rom'.
Now the phone only goes to the first Motorola page and stops.
Tried to enter CWM via 'vol up + vol dwn + pwr'; does not work.
Goes into a recovery I know nothing about, not CWM.
Tried 'vol up + pwr' and 'vol dwn + pwr'; neither work.
How is this solved?
I use Ubuntu 12.10, not Windows.
TIA
dlw
Posted 04 February 2013 - 06:52 AM
And use the Linux install.
Wooohoooo, Jelly Belly!
Posted 04 February 2013 - 10:39 AM
If medic's link doesn't work, or you have furter issues, let us know.
Posted 04 February 2013 - 10:53 AM
Followed this link to the letter.
When phone connected via USB cable, it says to be in 'Debugging mode.'
How do you do that when you can't get past the Moto logo?
Also, where exactly does the '246_FXZ' directory go.
I've got in Home directory and also in Root directory.
Thanks,
dlw
Posted 04 February 2013 - 01:07 PM
[sudo] password for dlw:
./utils/fastboot.linux: 3: ./utils/fastboot.linux: Syntax error: "(" unexpected
rm: cannot remove `/run/user/root/gvfs': Is a directory
Press Enter to continue when the phone is back in AP Fastboot
Posted 04 February 2013 - 04:37 PM
Posted 04 February 2013 - 05:04 PM
Boot into fastboot mode by holding all three buttons down for 10 seconds or more. Then scroll down to ap fastboot with vol down and select with vol up. Plug in the phone and run the 246 Fxz factory reset option.
Got into fastboot mode,
scrolled down to ap fastboot,
now I'm getting 'Battery Low, cannot program'.
Where is the 246 Fxz factory reset option; on the phone or the PC?
Thanks for replying.
dlw
Posted 04 February 2013 - 05:08 PM
dlw
On the PC. The HoB that was linked. If you turn the phone off will it charge?
Posted 04 February 2013 - 05:09 PM
Posted 04 February 2013 - 05:21 PM
Did the following as per instructions:
Installing FXZ (Linux):
o) Create a 246_FXZ directory in your HouseOfBionic directory
o) Extract the FXZ files TO THE ROOT OF the 246_FXZ directory.
root@dlw-HP:/# ls
bin dev HouseOfBionic lib mnt root selinux tmp vmlinuz
boot etc initrd.img lost+found opt run srv usr vmlinuz.old
cdrom home initrd.img.old media proc sbin sys var
root@dlw-HP:/# cd /HouseOfBionic
root@dlw-HP:/HouseOfBionic# ls
246_FXZ
root@dlw-HP:/HouseOfBionic# cd /HouseOfBionic/246_FXZ
root@dlw-HP:/HouseOfBionic/246_FXZ# ls
allow-mbmloader-flashing-mbm.bin logo.bin
boot.img mbm.bin
cdrom mbmloader.bin
cdt.bin mbr
device_tree.bin preinstall.img
ebr radio.img
emstorage.img recovery.img
grfs.img system.img
lbl VRZ_XT875_5.9.905.XT875.Verizon.en.US_CFC.xml
Linux/Mac:
LinuxMac_HouseOfBionic_(1.6).tar.gz:
MD5: 9ba67071472c92002cb978e53433219d
FXZ:
MD5: a72c1c1ab6d5717611fe12d63723e9c4
When the program runs, these errors appear:
The phone is in 'ap fastboot'.
Where exactly is /HouseOfBionic/246_FXZ directory to be located?
It is in Root and Home now.
Posted 04 February 2013 - 05:23 PM
Just press the power button to turn it off from fastboot and plug it in and see if it takes a charge.
Turn phone off,
Plug in power cord,
Phone boots up to Moto Logo and sits there.
No idea if it is charging or not.
No battery chanrging indicator of any kind.
Hopefully, it is.
Posted 04 February 2013 - 06:19 PM
Useing factory cable via wall charger.
Looks like I'm *****************************
Anyone here do inexpensive repairs?
- Gytole likes this
Posted 04 February 2013 - 06:52 PM
Unless you know someone with a bionic that will allow you to charge your battery. Verizon may charge it for you, as well
Posted 05 February 2013 - 07:22 AM
Where to from here?
Tried 'HouseOfBionic.sh' and the following is the results;
Linux/Mac House of Bionic Version: 1.6
Ready to flash fxz_keep...
* Flashing will take about 10-20 minutes
[NOTE: Your phone must be in AP Fastboot]
Get Ready To Break Out Your Sudo
Press Enter when ready to start flashing
Check for errors.
Press Enter To Continue
FXZ complete!
Press Enter to continue.
Thanks for using the House of Bionic!
Posted 05 February 2013 - 11:00 AM
Posted 05 February 2013 - 11:04 AM
That should have been a big clue. It's going to be a few hours before I can help you dig into this. No chance you have access to a windows box?
- johnlgalt likes this
Posted 05 February 2013 - 11:06 AM
Posted 05 February 2013 - 11:11 AM
Posted 05 February 2013 - 11:23 AM
Posted 05 February 2013 - 11:27 AM
