Avoided Poor Internet Connection Fix
6 replies to this topic
#1 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 06 February 2013 - 10:14 AM
DHCP stops working and the connection eventually throws "avoided poor internet connection" error message.
Turning off wifi and deleting all the files inside /data/misc/dhcp/ fixes the issue but it's not a permanent fix.
Hope This Helps, Worked Great for Me :)
Also Go Into Wifi Advanced Setting And Change Wifi region Code To United States.
Need Help? Send me a message
#2 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 07 February 2013 - 01:08 AM
Im assuming you talking about the CM10 bases out there... stock bases are fine on the wifi
#3 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 07 February 2013 - 03:05 AM
Yes, CM10 ROMs. I'm running CM10 inverted and after two days I had the connection error. This fixed it. Found this fix on the CyanogenMod Forums.
#4 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 07 February 2013 - 06:58 AM
Wifi connection fixer in the pay store also does the trick.
#5 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 07 February 2013 - 07:23 AM
I tried that and It did not work For me. Tried two different programs.
#6 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 07 February 2013 - 08:09 AM
Hmm, it worked for me...
#7 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 11 February 2013 - 03:03 PM
Yes that program does work I was using something else. Wifi connection fixer automatically does the process I explained in the OP.
