any differences between .39 and .41 ?
Posted 12 February 2013 - 08:54 PM
Posted 14 February 2013 - 07:08 AM
Posted 15 February 2013 - 08:11 PM
I figured it was pretty much identical so that's why we only have .39 deodexed . Thanks for the reply man its almost like a ghost town on this side of the fence! I hope to see more activity in the future with all these great developers upgrading from their OG RAZR's and OG MAXX's to (hopefully) hd's lol. I'm thinking of getting into the development community soon I just have to find time to do a lot of reading and practicing !I didn't notice much other than the fact that the newest version is official from VZW. The reason why no one has DD or zipaligned .41 is because with safestrap, you put your base OS on version .41, then it really doesn't matter if your ROM base is .39 or .41. Since it's running off the .41 Kernel, you're getting the same benefit of having that version installed.
Posted 16 February 2013 - 06:00 AM
Do it man, it's a lot of fun. I recommend you start off with building a theme to a ROM you run now. That will teach you how to use utilities and apktool. Not as time consuming as building a whole ROM, but still very rewarding. Also, I think dev support for this beast will only get better.
I need to get off my lazy arse and start updating my build. Just been crazy busy with my new job lately.
Posted 18 February 2013 - 10:50 AM
Sent from my DROID RAZR HD
Posted 18 February 2013 - 11:52 PM
If you took the ota update then you are on .41 now . The ROMs here are just based on .39 which is why I'm starting to believe I'm getting better performance and a little better battery life from my stock side . Im starting to think there may be some sort of a connection here . Either that or what some users have said its because of safe strap .Any way to get straight from .39 to .41 with out fastbooting?
- dunttt likes this
Posted 19 February 2013 - 05:02 AM
This right here... I knew next to nothing, but I started screwing around with the .39 base that was already deodexed and zipaligned and ended up releasing a rom of my own. It turns out to be really fun, but it's time consuming if you're a tad on the ocd side like me.
Posted 19 February 2013 - 10:00 AM
This did not answer my question.
I have been on rooted .39 for a while and am disappointed in performance compared to my wife's stock .41 phone.
Posted 19 February 2013 - 10:25 AM
So even you are seeing a difference in performance between the two builds . I think im going to read into learning how to deodex this .41 build . No one else seems to think its any difference between the two but at this point ive heard this from 4 different people.This did not answer my question.
Posted 19 February 2013 - 10:31 AM
But I did have Safe strap installed so I cannot rule that out either...
Posted 19 February 2013 - 10:44 AM
Posted 19 February 2013 - 11:04 AM
Posted 20 February 2013 - 10:52 AM
Same hereGeneral Lag for me. Nothing particular. Opening apps, typing, etc.
I'm going to go on ics for a while to compare the differences in the safestrap version of ics and the stock side of ics. That way we can determine if its safe strap vs .39/.41
Posted 20 February 2013 - 11:28 AM
Same here
Posted 20 February 2013 - 11:32 AM
Posted 20 February 2013 - 12:37 PM
you have .41 flashable in safestrap? I never thought to just run .41 odexed on safe strap. Do either of you guys have a safetrap .41 I could run? Of that runs better than .39 then I'll definitely be learning how to deodex it. There's a chance we could all be wrong about not being a difference in .39 and .41. But who knows right we can always try it out.Bone stock .41 is gravy in stock slot. Gonna run this for a while then stock ..41 in slot 1 to test difference
Posted 20 February 2013 - 12:53 PM
Posted 20 February 2013 - 11:00 PM
Me as wellHit me with the link to flashable .41 and I will run it
Maybe someone will create a rom based on .41 lol wishful thinking
Posted 21 February 2013 - 05:11 AM
Me as well
If it gets deodexed and zipaligned, I wouldn't mind upgrading my rom to .41
I don't know how intensive deodexing and zipaligning is.
Posted 21 February 2013 - 03:56 PM
I've heard it takes around 8 hours at least! :-(If it gets deodexed and zipaligned, I wouldn't mind upgrading my rom to .41
