Anybody else having battery drain problems after using this rom for a few days?
Funny you say that because I feel like my battery has only gotten better. Just got 1 day and 2 hours.
Posted 19 March 2013 - 01:57 PM
Posted 19 March 2013 - 08:05 PM
I've had about the same battery life with all versions of the ROM. Check to see if Beats is disabled. Unlike DSP manager, I've noticed that once you tweak the sound in Beats, it consistently remains running in the background.After the last update it seem to drain the battery faster than before
Posted 20 March 2013 - 03:38 AM
I'll do that and see if that's helps.
Posted 20 March 2013 - 07:01 AM
Posted 21 March 2013 - 05:43 AM
Posted 21 March 2013 - 05:46 AM
Posted 21 March 2013 - 09:33 AM
Posted 21 March 2013 - 07:33 PM
Posted 22 March 2013 - 05:44 AM
When you create a new ROM slot in SS, all it does is setup the partitions for you to safely flash a new ROM. After the ROM slot is created, you need to choose the "Install" option for that ROM slot. Then, you will choose the "Energy ROM" zip from your SD. Make sure you only install aftermarket ROMs in one of the additional ROM slots, not in stock. Once you are comfortable with the new ROM, there are ways to install the ROM in the stock slot, but that will come in play later on.
Posted 22 March 2013 - 02:35 PM
Posted 30 March 2013 - 04:36 AM
Posted 07 April 2013 - 11:01 AM
Posted 08 April 2013 - 03:31 AM
got Gtalk working - see this link:Can't seem to get Google talk to side load on this rom
ROM: OSE KitKat 4.4.2
Posted 08 April 2013 - 09:13 AM
Posted 08 April 2013 - 12:37 PM
Posted 08 April 2013 - 12:44 PM
Posted 08 April 2013 - 12:49 PM
So.. it seems there's a bootloader unlocker tool now available! Good bye safestrap.. it was a good run.
Posted 08 April 2013 - 12:52 PM
