[Testing] BatakangROM for XT912 -- Update: 2/7/2013
#201
Posted 03 January 2013 - 07:04 AM
- mhotovec likes this
#202
Posted 03 January 2013 - 07:45 AM
-Notification area toggles, including torch/flashlight.
-A 'reboot' option after long press on power button (added to 'power off' & 'airplane mode').
-The ability to change/reassign apps on the lock screen.
-Perhaps the Motorola M launcher and circle widgets, in addition to whatever browser you have in the ROM. Make it an option for those who like the widget.
#203
Posted 03 January 2013 - 09:01 AM
Reboot options on the power menu would be great.
Thanks Kebob!
- rickw likes this
#204
Posted 03 January 2013 - 09:06 AM
#205
Posted 03 January 2013 - 09:08 AM
++1I'd rather see quick settings than notification toggles.
Thanks Kebob!
#206
Posted 03 January 2013 - 11:40 AM
Thanks for all that you two (Matt & Kebob) have done for us!
#207
Posted 03 January 2013 - 05:47 PM
#208
Posted 03 January 2013 - 05:52 PM
#209
Posted 03 January 2013 - 06:10 PM
Did you flash on 3.11 or 3.07?I'm using it on 3.11,works great
#210
Posted 03 January 2013 - 06:25 PM
I flashed it on 3.11 with no problems. Have also backed it up and restored it with no problems.Did you flash on 3.11 or 3.07?
#211
Posted 03 January 2013 - 06:44 PM
Okay, thanks! What was your flash process? I can't seem to get mine to work. What rom-slot are you using?I flashed it on 3.11 with no problems. Have also backed it up and restored it with no problems.
#212
Posted 03 January 2013 - 06:55 PM
Used slot 2, but have also used slot one with no problems. I wiped cache and dalvak, formatted system and did the factory reset, then flashed the Rom and gapps together (version 4) the first time on slot one. Second time was version 6 and I followed the same steps, but used slot two. I flash a lot off roms (have probably tried every JB based Rom on this site) and have had no problems flashing any of them with ss3.11.Okay, thanks! What was your flash process? I can't seem to get mine to work. What rom-slot are you using?
#213
Posted 04 January 2013 - 10:02 PM
Yeah... Just re-read the head of this thread and realized that i need to be on JB leak " oops...Used slot 2, but have also used slot one with no problems. I wiped cache and dalvak, formatted system and did the factory reset, then flashed the Rom and gapps together (version 4) the first time on slot one. Second time was version 6 and I followed the same steps, but used slot two. I flash a lot off roms (have probably tried every JB based Rom on this site) and have had no problems flashing any of them with ss3.11.
#214
Posted 05 January 2013 - 11:10 AM
you can also use the dual kernel utility to run the JB kernel
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
#215
Posted 05 January 2013 - 11:24 AM
Ooh! How do? (If possible, please link)you can also use the dual kernel utility to run the JB kernel
#216
Posted 05 January 2013 - 11:35 AM
http://www.droidrzr.com/index.php/topic/6174-jb-dual-boot-xt912/Ooh! How do? (If possible, please link)
#217
Posted 06 January 2013 - 10:03 AM
#218
Posted 06 January 2013 - 04:14 PM
Did you go to: System settings, Accounts, gmail acct. & see if contacts is checked?been running Version 6 for about two days now and i can not seem to find a way to get my google contacts to sync. Everything else google synced (calendar, PLay, etc.) but contacts are empty! I have not tried much bc i dont kno where to start. I wiped everything before i flashed and it was a new slot. any help would be cool. I saw a gmail sync error in the earlier builds but gmail works for me, just no contacts
#220
Posted 06 January 2013 - 07:11 PM
Been there.i did. i just reflashed the rom and it fixed it. USER ERROR somewhere.
