Looking for a good micro usb cable that is not as stiff as the OEM one, but doesn't cause data or charging problems. Thanks.
Droid Razr Micro Usb Cable
bikebuilderdude
, Feb 18 2012 07:51 PM
1 reply to this topic
Posted 18 February 2012 - 07:51 PM
Posted 18 February 2012 - 08:03 PM
When I had my LG enV 2 I bought one at the local vzw store and it has a 90 degree angle and I'm still using it... I like using it in my truck with my universal phone mount, I feel a lot more comfortable when my phone is in portrait orientation, since the charge port is on the top.... so I really recommend a cord with a 90 degree end if you can find one.... buts that's just me
