Rom Toolbox Notification Background Theme Disaster
Posted 19 February 2012 - 09:05 AM
The moral of the story is.....
There is no moral. Just stay away from the notification background theme changer!!!
Posted 19 February 2012 - 09:51 AM
Posted 19 February 2012 - 09:52 AM
Sent from my XT912
- PillClinton likes this
Posted 19 February 2012 - 09:57 AM
Lol that's always exciting. Were you not able to restore through rom toolbox? I'm pretty sure it backs up your framework-res.apk and all just in case.
Sent from my XT912
Seconded, pretty sure Rom Toolbox backs up your current theme/icons, etc. At least in the pro version it does. However, like Thach, I've simply avoided messing with anything I get warned isn't compatible with the Razr so it hasn't been an issue for me (yet).
Posted 19 February 2012 - 10:00 AM
Haha I like the moral of the story. Sucks that you had to start from scratch but glad you were able to get back up and running. I thought about checking out some of those options but never had the guts to.
Stay way Thach. Stay away.
Posted 19 February 2012 - 10:02 AM
Posted 19 February 2012 - 10:07 AM
Let me know what your trying to change and what rom and I'll see what I can do.
Thanks Mopar! I'm running Abysm 1.1 and 24v's Icy Blue. I'm more than happy with 24v's theme though. It was just me trying to branch out a bit and experimenting. I'm not even sure exactly which background I selected. Just picked one at random.
I do have a question though. When you're theming (Take Abysm 1.1 in this case) are you limited to theming whatever DT already has on the ROM like the notification background in this case or can you add a completely new background of your choosing? Just curious.
Posted 19 February 2012 - 10:08 AM
Backed up but couldn't restore thru Toolbox since the force close kept popping up anytime I tried opening an app. Great start to my Sunday morning. LOL!!
Ah well I can see where that might be a problem. Its always exciting g when you play a little Russian roulette with your phone though haha!
Sent from my XT912
Posted 19 February 2012 - 10:10 AM
Sent from my XT912
LOL!!! Part of the process of shedding my noobishness. Can't make an omlette without breaking a few eggs I guess.
Posted 19 February 2012 - 10:20 AM
Sent from my XT912
#12 Guest_24v_*
Posted 19 February 2012 - 11:07 AM
My House......Can't make an omlette without breaking a few eggs I guess.
Posted 19 February 2012 - 11:16 AM
Since your on 24v's theme, you might want to talk to him about the background...i was thinking you were on stock.
As far as limits....this is a tricky question
Anything you see is possible to change..such as color images etc....as far as how things are set up then its possible, but i wont touch it. I leave things like this up to the developer. example would be to move his notification toggles to the bottom....stuff like this i wont touch....but to change the color or images used in the toggles i will.... Does this answer your question?
A good example would be to take 24v's theme and compare it to stock...if its changed then theres your answer
- raijin32 likes this
Posted 19 February 2012 - 11:46 AM
My House......
LMAO!!!
Posted 19 February 2012 - 11:47 AM
Yup! Answers it perfectly!
Posted 25 February 2012 - 04:39 PM
I think its a nice little tool to let you change the look of your most looked at part of your screen.
SOME ISSUES, that I have found so far...
Changing the signal strength bar colors currently is NOT working on STOCK roms.
If you change the status bar color to transparent you will end up with fading text and icons in your bar that can build up enough to distract from your text, although some may prefer this to provide a "ghost text" effect, also, if you change to any color of bar after setting transparent, it will keep the transparent settings, until you reload your backup of the stock bar, then change the color.
I am attaching a couple pics of what i am using on my stock 6.12.173
I would love to see if anyone has had any better luck changing the stock Signal Strength icons/colors for the stock updates.
353.64KB 16 downloads 365.45KB 18 downloads 404.34KB 15 downloads 344.43KB 9 downloads
Posted 21 March 2012 - 07:33 AM
