Installing roms
Posted 18 February 2013 - 11:06 AM
Posted 18 February 2013 - 11:17 AM
hey guys! im new here. I just rooted my phone last night. everything went well. I got a few questions though. I installed eclipse onto my bionic, but then i installed blurry max just a bit ago, and like it alot better. i also backed up my phone with titanium back up right after root and all before installing eclipse. im very low on internal memory and dont really like eclipse. can i just delete it? will everything still be in titanium backup? also when i installed blurry max, i chose the 1gb partion. i dont feel like this is going to be enough so can i just wipe this also and start all over with roms? with all my information still being in titanum backup so if i reinstall blurry, it will be fine? Thanks!
You can delete the Eclipse Rom slot and blurry but
make sure your Tibackup isn't stored on either one.Also.. I have found 1GB to be sufficient. I have all pictures and music sent to my EXTSD
Sent from my Icarus HD Edition Bionic
Posted 18 February 2013 - 11:26 AM
Posted 18 February 2013 - 11:34 AM
Posted 18 February 2013 - 11:36 AM
This is how mine is
33.62KB 17 downloads
Posted 18 February 2013 - 12:33 PM
Posted 18 February 2013 - 01:15 PM
Posted 18 February 2013 - 01:20 PM
Posted 18 February 2013 - 01:29 PM
Posted 18 February 2013 - 01:31 PM
Posted 19 February 2013 - 08:48 AM
ok thanks also for the blurry max update... just install this patch listed?
As to BlurryMax, install 3.8, let it boot, set it up and then install the 412 patch/update. FYI some folks were having problems with 412 but I saw in the Blurry forum that a new release of the patch was available for testing. I personally haven't had a chance to test it yet, but these DEVS all do great work (as well as all the themers like JayRod!). There are a couple of other good Blur based ROMS available also, Icarus and OverdriveBlur, I currently have both of these installed in different SS slots and switch back and forth as the mood hits! Hope this helps.
Cheers
