[Theme] Simplystock 173
Posted 19 February 2012 - 08:08 PM
This is SimplyStock with a touch of blue.
I am not responsible for what you do to your phone!!! You assume all risks involved.
Install Instructions:
Make sure you are on Stock .173
Recommended - Make a backup in recovery and reboot (always a good ideal before flashing anything) and have enough juice in case something goes wrong
Download the theme and place it on your sd-ext (not internal memory)
Reboot into recovery with Razr bootstrap
select choose zip from sd card and navigate to where theme is
select theme and confirm selection again.
When theme has finished installing go back and reboot
Enjoy!!!
24.13KB 120 downloads 72.26KB 135 downloads 69.55KB 92 downloads
Stock 173
SimplyStock with touch of blue - no longer supported
Revert to Stock 173 - no longer supported
- Hardtime3015 and mudthestud23 like this
Posted 19 February 2012 - 08:38 PM
Thanks. Had issues getting it to decompile/compile, both with apktool and apk manager but finally got it. First time its a pain to find everything after a few times it gets easier, lol. Last time I did it before the razr was back with Darkslide X for droidX, out of practice, lol.this is sweet wulf, i need some tips on how to change the settings like that.
Edit: If your going to try it I suggest you use the latest apktool.jar
#5 Guest_24v_*
Posted 20 February 2012 - 05:41 AM
#6 Guest_DirtyDroidX_*
Posted 20 February 2012 - 05:56 AM
^^^^^^^^^^^^^^^^^^^that was my wolf howl
Posted 20 February 2012 - 08:25 AM
Call settings you might want to leave alone, it can cause white text on white background in some areas like recent call(it annoys me so I leave it lol)Did you get the "Call Settings", "Data Manager", and "Accounts" screens inverted too? I have changed a bunch in Settings, but I still have not gotten those 3 inverted.
Data manager is not hard, I can do it.
Accounts shouldn't be hard either, haven't tried.
Awesome!!!Ahhh this is simple and perfect. rrwoooooooo
Posted 22 February 2012 - 08:37 PM
Sent from my DROID RAZR using Xparent Red Tapatalk
Posted 22 February 2012 - 09:42 PM
Thanks. Glad ppl like it.This seems to be a hit. Have you considered making more? Oh and you accepting donations? I know a few people don't like to and I respect that. But I also believe in compensation for hard work and time spent and this is no exception with our devs and themers.
Yeah, i can do more themes for stock. I actually do like some of the features from the anti-christ called "BLUR", lol.
Just let me know what themes that ppl would like and ill port them. I will also consider requests, just let me know.
If people would like to donate i can put a link in the OP of the theme threads or is there a different way to do it? I like to theme, its become an obsessive hobby and I like to share what i do.
Posted 03 March 2012 - 07:14 AM
Posted 03 March 2012 - 07:24 AM
Posted 03 March 2012 - 07:46 AM
Download and flash revert to stock zip in op, reboot and go back and flash theme. Should be good after that.
Perfect thanks. Great work.
Posted 03 March 2012 - 07:47 AM
Posted 10 March 2012 - 10:25 PM
Posted 10 March 2012 - 10:37 PM
Download revert to stock zip and flash it and reboot. Then flash theme again and it should work.after i flashed this i lost my settings lol
Sent from my XT875 using Tapatalk
Posted 10 March 2012 - 11:32 PM
Posted 10 March 2012 - 11:53 PM
I sent you a PM, I'll help you from there.cant get back into clock works now since i have no settings for
Posted 11 March 2012 - 09:50 AM
Posted 11 March 2012 - 10:00 AM
That is caused by the settings being inverted. If you flash the revert to stock zip in the op, reboot and then flash theme it will work and you'll have settings back.For some reason when I apply this theme my settings menu and manage apps. disappear. Any answers?
